8000$ system split between only speakers and integrated amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-03-2014, 07:30 PM - Thread Starter
motobonsai's Avatar
Recently came into some funds.
I need a 2 channel system for a room 18x22 with 10 ft ceilings. Source is squeeze box with some high rez. But mostly alternative, jazz and female voices.
So divide $8000 between only speakers and int. Amp.
No tubes.
Not too keen on a subwoofer.
motobonsai is offline
post #2 of 5 Old 05-04-2014, 04:55 AM
glangford's Avatar
Quoted: 198 Post(s)
Liked: 170
No tubes.
I don't care for a sub either, so I went a tower speaker with a rather low F3. Supercharged Salk Songtowers. Depending upon your listening tastes you might want a speaker with a little more oomph. The veracity songtower is another option. Slightly bigger is the HT2-TL at about 4500 (34 hz). Or you can go all the way with the Soundscape 8 at 7999 which will play down to 25 hz.
Give Salk a try. Send him an email, tell him what you are looking for, he'll usually answer in a day.
As far as integrated amps, I just use a fairly high end AVR. Put more money in your speakers and worry less about the amp.
glangford is online now
post #3 of 5 Old 05-04-2014, 06:53 AM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
Aerial 6T's along w the NAD 390DD integrated would make a nice combo.smile.gif
motobonsai likes this.
Class A is offline
post #4 of 5 Old 05-04-2014, 08:16 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
My choice for an integrated amplifier would be the Musical Fidelity M6i It is superb and has all the power anyone can use. Around $3000, I think.
Another excellent one is the Arcam A38, which costs around $2400.
For speakers, I would choose the Vandersteen 3A Signature ($4495).
They were always excellent, and have recently been improved by the addition of the same midrange driver and tweeter used in the Treo speakers (which I have).
commsysman is offline
post #5 of 5 Old 05-04-2014, 06:03 PM
Jack D Ripper's Avatar
Liked: 272
Magnepan MG 3.7i for $5500. The integrated amplifier would depend on how loud you wanted to play them. For reasonable levels, a Yamaha A-S1000 for $1300 would be sufficient.
If you don't mind going with separates instead of an integrated amp, you could go with an Emotiva digital preamp for $269 and then if you wanted to have massive power, you could get an Emotiva XPR-2 for $1799, which will put out a thousand watts per channel into 4 ohms (the impedance of the Magnepan speakers).
God willing, we will prevail in peace and freedom from fear and in true health through the purity and essence of our natural fluids. God bless you all.
Jack D Ripper is offline
Reply 2-Channel Audio
