Best Foobar settings for 2ch audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-15-2014, 01:48 AM - Thread Starter
xframe88's Avatar
Hi all,
I am intending to use an Intel NUC pc with windows 8.1 as an audio playback device, via a USB soundcard. I just wanted some simple suggestions around how to achieve best music quality.
After trying most software, I have decided Foobar suits me best, so my questions are:
* Is there any need to use additional output components such as WASAPI when using Windows 8.1?
* All I need to do is pass SPDIF audio via USB from the PC to my Denon AV receiver, is there any need to spend much on the USB interface, given I will not be using any DAC (the Denon will do that). Any suggestions for a good quality USB device?
* I hope to playback high resolution audio files, mainly 24/96 flac, any suggestions on how to best setup Foobar for this?
Many thanks for any help.
xframe88 is offline
post #2 of 5 Old 06-15-2014, 05:57 PM
RayDunzl's Avatar
Quoted: 1228 Post(s)
Liked: 1429
There are many tutorials on this subject. Here is one:
http://www.whathifi.com/forum/comput...-to-use-wasapi
Older AVS discussions here:
https://www.google.com/search?q=site...ks+asio+foobar
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
post #3 of 5 Old 07-26-2014, 12:55 AM
hdtv00's Avatar
Quoted: 131 Post(s)
Liked: 72
Foobar using WASPI to keep things bit perfect out to an Aune T1 using orange globe near audio Nirvana using my HD 650's.
Marantz 7702MKII/Outlaw 7140 65" 4k Samsung KS8000
i7 4770K/16 gig 2133/970's SLI 840 PRO SSD
Paradigm Studio v3 100/570/20's/2200 Sub
hdtv00 is offline
post #4 of 5 Old 07-26-2014, 04:29 PM
almo89's Avatar
Quoted: 57 Post(s)
Liked: 56
Is it possible to bit stream DSD files through HDMI? I'm only able to listen to them via PCM. I searched all over trying to find this answer and tried a bunch of tutorials, but can't seem to get it to work.
almo89 is offline
post #5 of 5 Old 07-28-2014, 03:06 AM
RayDunzl's Avatar
Liked: 1429
RayDunzl is offline
Reply 2-Channel Audio
