Klipsch 2.1 ProMedia upgrade - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-01-2014, 12:49 PM - Thread Starter
lml999's Avatar
I've been running an older Klipsch 2.1 ProMedia setup with my home computer. The Klipsch is considered pretty good as far as desktop 2.1 systems go, but I figured that I could do better.
So I picked up a pair of Minimus 7 speakers and swapped them in for the Klipsch satellites. It doesn't appear that Klipsch tweaked the satellite outputs for their speakers as the setup sounds pretty good, a lot better than with the original sats. The M7s have some pretty good detail...
Now, on to upgrading the M7s.
lml999 is offline
post #2 of 5 Old 07-01-2014, 03:35 PM
BayStateTech's Avatar
Liked: 3
I have the same setup from Klipsch. I never considered swapping out the two satelites. If I swap in two 8 Ohm speakers, how much power output can the amp put out?
BayStateTech is offline
post #3 of 5 Old 07-03-2014, 10:20 AM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
Are you talking about POWERED speakers or passive speakers?
For $40 per pair, the Dayton B652 speakers are incredibly good. I have a pair in my den with a Cambridge amplifier, and they are much better than the expensive Boston speakers they replaced.
If you want POWERED speakers, the Audioengine 2 speakers are hard to beat for a computer setup.
commsysman is offline
post #4 of 5 Old 07-03-2014, 12:24 PM - Thread Starter
lml999's Avatar
Passive.
The Klipsch subwoofer is an active subwoofer, and also powers the two satellite speakers. The Minimus 7s replaced the Klipsch passive sats.
lml999 is offline
post #5 of 5 Old 07-03-2014, 09:01 PM
zieglj01's Avatar
Quoted: 941 Post(s)
Liked: 846
Passive.
Next step - the Focal Sib, a different league of speakers
http://www.accessories4less.com/make...s-black/1.html
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
Reply 2-Channel Audio
