Recording WAV/FLAC 24 Bit 96Khz or 24 Bit 192Khz - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-18-2014, 10:03 AM - Thread Starter
isai95's Avatar
What software do you guys use to record high quality audio and which of the two formats do you prefer? Thanks.
isai95 is offline
post #2 of 5 Old 07-18-2014, 05:20 PM
charliw's Avatar
I use Audacity and record 96kHz/24-bit FLAC files. I can do 192kHz/24-bit audio but even compressed, the file size is quite large. I would not even bother with .wav because the files get very large and unwieldy to convert, move or use.
charliw is offline
post #3 of 5 Old 07-19-2014, 04:03 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I use Adobe Audition for recording, and 24/96 unless I use 16/44.
arnyk is offline
post #4 of 5 Old 07-25-2014, 09:33 AM - Thread Starter
isai95's Avatar
I've been trying Cakewalk, Goldwave and Audacity for Windows 7. Audacity was the best for me. I've been doing recordings from LPs at 96kHz/24-bit WAV and 192khz/24-bit WAV files. The quality is very acceptable.
My portable player does not recognize the 192khz/24-bit WAV files; but I'm planing on building a computer for audio only with a couple of 4TB hard drives, 16GB of Memory, a good motherboard with a Xonar Essence STX sound card to feed my tube amplifier.
isai95 is offline
post #5 of 5 Old 07-25-2014, 09:37 AM - Thread Starter
isai95's Avatar
What type of source do you record from? LPs, Music keyboard, Regular piano, 24/96 digital streaming?
isai95 is offline
Reply 2-Channel Audio
