How much difference of 24 ohm vs. 64 ohm makes on a portable CD player - AVS Forum | Home Theater Discussions And Reviews
Old 07-25-2014, 04:54 AM - Thread Starter
happy hopping's Avatar
Quoted: 58 Post(s)
I am thinking of get a new headphone, natural wood construction. My current headphone is 24 ohm, a Sony MDR-V900.
I have also use the Sony MDR-V600, which is 45 ohm, on the same portable CD player.
In either case, I can't tell a difference in sound quality. But people did tell me that the lower the impedance, the better it is for the battery to push good CD sound quality.
The current headphone I have in mind is 64 ohm. Would a regular portable CD player or Hi MD player be able to push good Cd quality sound on a head phone of 64 ohm ?
happy hopping is offline
Old 07-26-2014, 07:36 AM
oztech's Avatar
Liked: 101
The lower the impedance the longer the battery life because you do not have to turn the volume up as loud for the same output.
Lower impedance will sometimes introduce hiss on quite passages depending on the quality of the player and source.
The higher the impedance over 100ohm the need for better voltage swing from the player or amp.
oztech is offline
Old 07-31-2014, 10:05 AM
cel4145's Avatar
Quoted: 2659 Post(s)
Liked: 2991
That's not entirely accurate. Headphones vary in sensitivity. So a sensitive 64 ohm headphone might use less power than a less sensitive 32 ohm headphone.
However, you could always pick up a FiiO E11 headphone amp to use with your CD player. That would drive most headphones to very loud volumes.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Old 08-01-2014, 06:59 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Hold that thought.
People say the darndest things, many guided by what they heard who knows where from who knows who? Other comments are based on what is intuitively clear, but a lot of electronics isn't intuitively clear, which is why we have engineers.
There isn't that much difference between the two impedances you mention. Other relevant parameters such as over-all efficiency could be far more important, as others have already pointed out.
arnyk is offline
Old 08-02-2014, 01:51 AM - Thread Starter
Quoted: 58 Post(s)
Originally Posted by arnyk View Post
Hold that thought.
when I first post that question, because my headphone has hissing sound, I assume it's dying, and that it's 10 yr. old, so I have my eyes on a Ultrason Signature Pro or an Audio technica ESW-9a.
In the end, when I went to sony to do a A-B test between my 10 yr. old MDR-V900 vs. their brand name MDR-1RNC, I can't tell the difference in sound quality, and when the same song (LPCM) is tested by the sony salesman, he also said there is hardly any difference.
So in the end, I only have to replace the headphone jack, and no longer need to worry what a higher impedance can do.
thanks every1 for your input
Old 08-02-2014, 02:11 AM
jb82's Avatar
Quoted: 18 Post(s)
I think it will have a pretty big effect. I have 50 ohm headphones that I use with new walkman cd player and to get a strong full sound I have to turn it up almost all the way with older cd's that are not super loud. Just get an amp if you feel the need to. I get great SQ when I plug the walkman into an outlet big difference with batteries.
jb82 is offline
