Power/Wattage meter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-26-2014, 09:46 AM - Thread Starter
musicfan75's Avatar
Power/Wattage meter
Hello everyone,
Does anybody know that if there is a power meter that I can hook up to my pre amp or amplifier that can read the power/wattage
that I am using?
Thanks!!
musicfan75 is offline
post #2 of 3 Old 07-26-2014, 12:12 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Originally Posted by musicfan75 View Post
Hello everyone,
that I am using?
Thanks!!
The Kill-A-Watt is IME the go to tool for a low priced but reliable and accurate meter of numerous parameters related to AC Power. Watts, Volt-amps, phase angle, voltage, frequency...
Some big box home improvement stores have them, but they are available all over the web.
arnyk is offline
post #3 of 3 Old 07-26-2014, 05:11 PM
RayDunzl's Avatar
Quoted: 1230 Post(s)
Liked: 1431
Kill-a-Watt is good, I have two of them.
Amps: 100w each idle but ready , preamp 70w, and another 100w for cable box and cd player and HDRadio and ethernet hub and DAC and...
Ballpark $1/watt for yearly cost if 24hr usage.
http://www.amazon.com/s/ref=nb_sb_no...%3Akill-a-watt
The Kill-A-Watt EZ is good, extra features over the base model.
Neither is illuminated so get a flashlight too.
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
Reply 2-Channel Audio
