Amp Stands - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By A9X-308
post #1 of 18 Old 07-31-2014, 11:01 AM - Thread Starter
larry7995's Avatar
Quoted: 49 Post(s)
Liked: 63
Amp Stands
What do you folks like for amp stands for heavy (100 lb) monoblocks? I see some cool ones in photos.
larry7995 is offline
post #2 of 18 Old 07-31-2014, 11:09 AM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
Amps don't need stands at all. They're used by most audiophools to build a shrine where they can worship and venerate the imagined gods of audio.
Hbcueducated likes this.
A9X-308 is offline
post #3 of 18 Old 07-31-2014, 11:20 AM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1687
I don't like amp stands but I recommend you choose whatever looks nice to you.
FMW is offline
post #4 of 18 Old 07-31-2014, 03:05 PM - Thread Starter
larry7995's Avatar
Quoted: 49 Post(s)
Liked: 63
Well in my case at least they would keep the amp above the german shepherd hair that seems to accumulate everywhere on a daily basis.
post #5 of 18 Old 07-31-2014, 03:57 PM
Will2007's Avatar
Quoted: 14 Post(s)
Liked: 136
It won't raise your amps, but putting one of these in the room might keep the dog hair away.
Will2007 is offline
post #6 of 18 Old 07-31-2014, 07:21 PM
89grand's Avatar
Quoted: 289 Post(s)
Liked: 163
That about sums it up. If one really just doesn't want their amps sitting on carpet, a few granite tile slabs from Home Depot should do the trick and they're only maybe $5 each at the most depending on the style, You'd probably need 8 as they're 12x12".
89grand is offline
post #7 of 18 Old 07-31-2014, 08:01 PM - Thread Starter
larry7995's Avatar
Quoted: 49 Post(s)
Liked: 63
post #8 of 18 Old 08-01-2014, 05:00 AM
Class A's Avatar
Quoted: 432 Post(s)
Liked: 1711
Smile
Check out VTI, Timber Nation and Sanus.
Years ago I lucked out by getting a pair of Zoethecus amp stands for $25 ea. Having Class A amps they have provided maximum ventilation.
Class A is offline
post #9 of 18 Old 08-01-2014, 05:12 AM - Thread Starter
larry7995's Avatar
Quoted: 49 Post(s)
Liked: 63
I believe you were talking about this one
http://www.soundstage.com/revequip/a...nce_dakota.htm
post #10 of 18 Old 08-01-2014, 05:33 AM - Thread Starter
larry7995's Avatar
Quoted: 49 Post(s)
Liked: 63
These are not terribly expensive and probably what I will get.
http://www.amazon.com/BL404-Addition...64SCX75BSNPK7E
post #11 of 18 Old 08-01-2014, 05:35 AM - Thread Starter
larry7995's Avatar
Quoted: 49 Post(s)
Liked: 63
These are a litle pricey but not too bad, and would look very nice in the room.
http://www.timbernation.com/astand_popup.cfm
post #12 of 18 Old 08-01-2014, 01:54 PM
A9X-308's Avatar
Liked: 1142
No. I was talking about all of them.
A9X-308 is offline
post #13 of 18 Old 08-01-2014, 02:59 PM
Class A's Avatar
Quoted: 432 Post(s)
Liked: 1711
Smile
The VTI stands are very good looking and should do the job for your big amps. Yeah granite blocks and tile can do the job. But we all have to grow out of the Dorm look sometime. There is nothing wrong in building a shrine. It should look as good as it sounds,
Class A is offline
post #14 of 18 Old 08-01-2014, 10:17 PM
novisnick's Avatar
Liked: 29
I agree, I found a 16" x 16" ,or about that, garden step tile and you don't even see it but the amp is up off the floor.
I found it to be cheap and perfect.
novisnick is offline
post #15 of 18 Old 08-01-2014, 10:19 PM
novisnick's Avatar
Liked: 29
I've seen them cheaper on there own site, give it a look.
post #16 of 18 Old 08-01-2014, 10:32 PM
Orbitron's Avatar
Quoted: 503 Post(s)
Liked: 389
Kanso Audio Furniture can make your amp stands custom to your needs or anthing else stand related.
http://www.kansoaudiofurniture.com/p389.html
Orbitron is offline
post #17 of 18 Old 08-08-2014, 07:03 AM
Lonely Raven's Avatar
Quoted: 34 Post(s)
Liked: 42
My tube amp (as all are) is susceptible to noise from vibrations. Adding tube dampers and an amp stand has shifted (most of) the vibrations to frequencies outside the audible range improving the micro-dynamics.
If we're talking a standard receiver and *most* transistor amps, I agree, amp stands are more for show than anything else. But even transistor amps can benefit from some physical damping of vibrations. Why that is, I couldn't say - I'm a tube guy.
Lonely Raven is offline
post #18 of 18 Old 08-08-2014, 04:21 PM
A9X-308's Avatar
Liked: 1142
Show me the measured evidence that supports this assertion.
Ditto.
A9X-308 is offline
Reply 2-Channel Audio
