Swapping Ortofon 2M Red stylus with a 2M blue stylus? - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By audio4life
  • 1 Post By Tgterm
  • 2 Post By Ratman
post #1 of 22 Old 08-04-2014, 05:19 PM - Thread Starter
Tgterm's Avatar
Quoted: 172 Post(s)
I was considering an entry level TT to get back into vinyl. The one I have been looking at has a pre installed Ortofon 2M Red cartridge. I wanted to check if anyone has had any experience swapping the red stylus for a 2m blue stylus -- I have read that they are interchangeable, but the blue was a better performer. So, based on this, theoretically I can pop in a new stylus and reap some additional benefit without a full cartridge swap, I suppose.
Anybody ever do this?
Thank you very much for any input.
Tgterm is online now
post #2 of 22 Old 08-05-2014, 08:31 AM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
The styli may be physically interchangeable, but they are not compatible for technical reasons.
If you want to upgrade, you need to buy the better cartridge.
commsysman is offline
post #3 of 22 Old 08-05-2014, 11:15 AM - Thread Starter
Tgterm's Avatar
Quoted: 172 Post(s)
Thank you for the reply. I asked because I thought I had read that the actual body of the cartridges were exactly the same, and that the only difference could be found in the styli. Hence, my question about upgrading just the stylus on the red. I must have misinterpreted what was written...
Much obliged!
post #4 of 22 Old 08-05-2014, 11:25 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
I think you're over-thinking the performance differences involved. Vinyl itself is the challenge, not particularly the cartridge and the red is a competent cartridge....especially if it comes installed on the tt, just use it!
lovinthehd is offline
post #5 of 22 Old 08-05-2014, 11:45 AM - Thread Starter
Tgterm's Avatar
Quoted: 172 Post(s)
Probably... But overthinking this stuff is half the fun! What you're suggesting is likely what I will do...
post #6 of 22 Old 08-05-2014, 07:57 PM
audio4life's Avatar
Liked: 299
Much obliged!
The Ortofon site ( http://ortofon.com/hifi/products/car...series/2m-blue ), under the heading Technical Data, indicates that they are interchangeable and I would suspect that they've only say that if it was recommended as an option.
I concur with your sentiments regarding 'overthinking' things. Vinyl fans know that cartridges vary in performance and part of the fun is experimenting. I've got the 2M Red too, which retails for about 100. By all counts its a good entry level cartridge, but this is a technology in which more money really can get you more SQ. I'd love to try moving coil designs as they have superior high end reproduction, but cost much more. It never ends!
jb82 likes this.
audio4life is offline
post #7 of 22 Old 08-05-2014, 08:09 PM - Thread Starter
Tgterm's Avatar
Quoted: 172 Post(s)
It certainly never ends. That is a true statement! ;-)
Thanks for the link...
jb82 likes this.
post #8 of 22 Old 08-06-2014, 11:22 AM
lovinthehd's Avatar
Liked: 4775
I read that as perhaps saying they use the same stylus...
post #9 of 22 Old 08-06-2014, 11:50 AM - Thread Starter
Tgterm's Avatar
Quoted: 172 Post(s)
^actually, they are different styli... Apparently interchangeable.
post #10 of 22 Old 08-06-2014, 11:56 AM
lovinthehd's Avatar
Liked: 4775
How do they differ? I didn't see anything particularly saying that....
post #11 of 22 Old 08-06-2014, 12:39 PM - Thread Starter
Tgterm's Avatar
Quoted: 172 Post(s)
Nude elliptical vs. Elliptical... Some other sources I have found get into more details... Different diamonds?
post #12 of 22 Old 08-06-2014, 02:34 PM
lovinthehd's Avatar
Liked: 4775
I don't see how nude elliptical is necessarily different than elliptical unless the inference is there is a tipped diamond used on the "elliptical"? I see this on Ortofon's site https://ortofon.com/images/stories/s...lus%20type.pdf
Could just be marketing speak....
post #13 of 22 Old 08-06-2014, 03:57 PM - Thread Starter
Tgterm's Avatar
Quoted: 172 Post(s)
Dunno...I lifted this from a comparison...
Sharing the same cartridge body, the Ortofon 2M stylus of the Ortofon 2M Blue differs from the 2M Red being nude elliptical rather than just elliptical. The nude stylus has the diamond punched through the cantilever, which produces less distortion than the Red (which uses a smaller diamond adhered to a tube - called shank - which is then adhered to the cantilever). This is a more expensive process but it means better tracking and a higher frequency range at 25,000 Hz compared to 22,000 Hz.
See link:
http://www.theapplechap.webspace.vir...d_or_Blue.html
post #14 of 22 Old 08-07-2014, 01:33 AM
lovinthehd's Avatar
Liked: 4775
Just seems odd from that Ortofon link I posted that they were saying diamond tipped stylus wasn't so hot (but didn't indicate which was which in their lineup)
post #15 of 22 Old 08-07-2014, 07:01 AM
Ratman's Avatar
Quoted: 1271 Post(s)
Liked: 1022
https://system.netsuite.com/core/med...ry=US&gc=clear
Personally... I'd enjoy the 2M Red and use the ~$200 for a replacement Blue stylus to buy some LP's.
David Susilo and lovinthehd like this.
Ratman is online now
post #16 of 22 Old 08-08-2014, 10:52 AM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
This is pretty similar to the Ortofon OM line. The bodies of the OM-5, OM-10, etc are the same. The differences in the models were the stylii. They were interchangeable on that line as well, providing an upgrade path.
jdcrox is offline
post #17 of 22 Old 08-10-2014, 10:56 AM
audio4life's Avatar
Liked: 299
I don't know, instead of repeatedly posting skepticism, why don't you contact Ortofon, or an Ortofon dealer and express your skepticism to them. Then report back with their response.
post #18 of 22 Old 08-13-2014, 01:25 PM
lovinthehd's Avatar
Liked: 4775
Just trying to see what actual knowledge there is about the various differences.... No interest in a new cartridge or clarification from Ortofon in any case, my Grado at its current use level will last me the rest of my life....
post #19 of 22 Old 08-14-2014, 04:29 PM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
The price of a 2M Blue stylus is about $170. A 2M Blue Cart is $225. Hardly worth the savings. If you want a 2m Blue but the cart. By the way how skilled are you at switching out a stylus?? It can be tricky to a novice.
Class A is offline
post #20 of 22 Old 08-14-2014, 04:38 PM
Ratman's Avatar
Liked: 1022
How so?
post #21 of 22 Old 08-14-2014, 04:44 PM
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
Maybe my TT and/or entire system and/or my ears are not sensitive enough. I borrowed my friend's Blue (at the same time I bought my Red), and although I can hear differences, I can't make up my mind which I like better...so I use the Red and use the money to buy...blu-ray movies (I know the logic is flawed, but at the time I just bought the Beatles vinyl box set, I can't bring myself to buy more LP)
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #22 of 22 Old 08-16-2014, 03:07 PM
gajCA's Avatar
Quoted: 2012 Post(s)
Liked: 1178
I used Ortofon Moving Coils for decades with my Revox B795 TT which I have since given to my daughter.
That being said, I am very pleased with the fidelity of the Ortofon Red supplied with my Pro-Ject Carbon Turntable.
When (or if) the Red Stylus ever wears out I will replace it with the Blue just for fun.
But not sure if it will wear out as that would be at about 500 hours and I don't have that many hours of vinyl left to digitize which is what I've been using my turntables to digitize.
So, from me, who's owned turntables since 1974 and have had experience with top of the line Stantons, Shure's as well as Ortofon Moving Coils, the Ortofon gets a score of 9 out of ten.
Love the Pro-Ject Carbon but it's actually my very first fully manual Turntable.
I loved my Sony PSX75 Turntable which I traded with my Dad for his Revox B795 because the Sony tracked warped records better.
I wish I had grabbed that Sony PSX75 back after he died, to be honest.
Nevertheless the manual Pro-Ject with the Ortofon Red is a fine combination and certainly nothing you should be ashamed of or feel needs an immediate upgrade.
gajCA is offline
Reply 2-Channel Audio
