Audyssey Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-06-2014, 11:39 PM - Thread Starter
Liked: 0
Audyssey Setup
First time calibrating, are these normal results? Also I have 2 bookselfs (kef ls50) as my L R but audyssey is reading them as large. I also have an outlaw sub. If I change from large to small does it cancel the calibration since it can only be changed on manual setup? This is for movie watching. Any help would be appreciated. Oh the receiver is an denon x2000
ID:	200809   Click image for larger version
ID:	200817   Click image for larger version
ID:	200825   Click image for larger version
ID:	200833   Click image for larger version
drivermacias is offline
post #2 of 4 Old 08-07-2014, 04:06 AM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3546
1. Looks fine.
2. No problem; you can switch from Large to Small. ..And it won't affect Audyssey EQualization.
* To help you more, check the Audyssey Setup Guide, and Audyssey FAQ. ...Few prominent members here have them links in their sig.
Or ... click => Audyssey Setup Guide
P.S. For Movie watching? ... 2 Channel Audio thread ...
NorthSky is offline
post #3 of 4 Old 08-07-2014, 06:12 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
Set your speakers to small. You will probably want the crossover at 80Hz. See where it says your sub trim is -12.0dB? This means your sub is too loud. You need to turn the sub down to about 30-40% and re-run Audyssey. The goal is to get the trim level in the receiver for the sub to 0dB (or with 0.5dB). Once you find the right position for the volume knob on the sub, leave it there, and change the volume in the receiver if you want more/less bass. Also make sure the sub crossover setting is at the maximum, this disengages the subs low-pass filter and let the receiver handle bass management.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #4 of 4 Old 08-07-2014, 04:07 PM
pbarach's Avatar
Quoted: 318 Post(s)
Liked: 193
Originally Posted by NorthSky View Post
1. Looks fine.
Here ya go--this links to some of the best advice I have found on AVS about anytbhing:
"Official" Audyssey thread (FAQ in post #51779)
And that thread, though sometimes contentious, has a host of very helpful people to help you get the best results with Audyssey (first step--buy the inexpensive boom mic stand and do the calibration again--it makes the job easier, and some say you get better results than with a camera tripod).
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
Reply 2-Channel Audio
