portable 2 channel - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 1 Post By arnyk
  • 1 Post By arnyk
  • 1 Post By cel4145
  • 1 Post By RayDunzl
  • 1 Post By cel4145
  • 1 Post By arnyk
post #1 of 13 Old 08-31-2014, 09:24 AM - Thread Starter
eljr's Avatar
Quoted: 1050 Post(s)
Liked: 8025
portable 2 channel
I want to have decent sound at the lake house or out behind the barn, maybe one of the porches.
I was thinking maybe a lap top to a pair of powered speakers?
IS there a better idea?
recommendations on speakers and connection explanation would be appreciated.
eljr is offline
post #2 of 13 Old 08-31-2014, 12:13 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
How about some of the portable Bluetooth speakers?
crn3371 is offline
post #3 of 13 Old 09-01-2014, 04:43 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Probably the best way to do this is:
(1) A portable music player or smartphone. If you have a laptop, then it could be very good, but I wouldn't and don't use mine that way because I have a few good portable music players and for just music they are more convenient.
(2) The player may have to have its storage extended with a uSDHC card to hold enough music to please you. Web media access may not be practical or even possible depending on where your vacation home.
(3) You will probably need some kind of external power source for this equipment if you like to listen for music for hours
(4) A pair of powered speakers, depending on how loud and how large of a space to be covered. This can range from better computer speakers to small studio monitors to a fairly capable PA system.
eljr likes this.
arnyk is offline
post #4 of 13 Old 09-01-2014, 11:39 AM - Thread Starter
eljr's Avatar
Liked: 8025
so my sole source becomes the laptop, i just play the music in jrivers and how do i connect directly to the monitors?
i don't need to go through a preamp of any kind? no external dac?
how do i then make the connection between laptop and powered speakers or monitors?
eljr is offline
post #5 of 13 Old 09-01-2014, 12:53 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
True.
If you want to connect powered speakers to the audio outputs of a laptop, obtain the proper cable which may vary with the speakers you choose.
Here is a common example:
http://www.monoprice.com/Product?c_i...seq=1&format=2
One end looks like this:
The other end looks like this:
The 3.5 mm audio output jack on a laptop is similar to the line level outputs that are common on CD players and preamps. So they will drive the same things. The laptop has a volume control. Usually, an external preamp is unnecessary.
eljr likes this.
arnyk is offline
post #6 of 13 Old 09-02-2014, 01:41 PM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2990
If you want something very portable, the Sansa Clip+ and Clip Zip are great little inexpensive mp3 players that take micro SD cards. I use mine with a JBL Charge bluetooth speaker as my portable jukebox. You could do something similar with powered speakers to make your setup a little more portable.
What is your budget for speakers? And will you have power where you plan to use the speakers, or are you wanting battery powered?
arnyk likes this.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #7 of 13 Old 09-02-2014, 02:37 PM
RayDunzl's Avatar
Quoted: 1228 Post(s)
Liked: 1429
Maybe you could be a little more specific in your expectations...
Are they going to be mounted, or portable, or AC powered, or batteried, for ambience, or parties or what?
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
post #8 of 13 Old 09-02-2014, 03:56 PM - Thread Starter
eljr's Avatar
Liked: 8025
ac power, portable.
to old to party so they are just so i am not without music
i am not big on headphones and don't use earbuds
eljr is offline
post #9 of 13 Old 09-02-2014, 04:24 PM
RayDunzl's Avatar
Liked: 1429
In that case...
Maybe something like this to your laptop or LMP (little music player)
http://www.behringer.com/EN/products/STUDIO-50USB.aspx
eljr likes this.
RayDunzl is offline
post #10 of 13 Old 09-02-2014, 04:36 PM
cel4145's Avatar
Liked: 2990
Can you tell us your budget?
Look into the TDK A33. It gets surprisingly loud and sounds pretty decent for its price. It's also weather resistant.
eljr likes this.
cel4145 is offline
post #11 of 13 Old 09-02-2014, 08:01 PM
RayDunzl's Avatar
Liked: 1429
Actually this one might have slightly better connectivity
http://www.behringer.com/EN/Products/MEDIA-40USB.aspx
eljr likes this.
RayDunzl is offline
post #12 of 13 Old 09-03-2014, 08:46 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
ac power, portable.
I am not big on headphones and don't use earbuds
These are all powered monitors
Smaller (in no particular order within this group)
(1) Behringer B3020A
(2) JBL Pro LSR 305
Larger: (in no particular order within this group)
(3) Behringer B3021A
(4) JBL Pro LSR 308
The Behringers have a mini 1/8" mono input jack, while the JBLs have a 1/4 inch mono phone jack, so they will require different adapter cables. Monoprice is your friend.
eljr likes this.
arnyk is offline
post #13 of 13 Old 09-03-2014, 11:21 AM - Thread Starter
eljr's Avatar
Liked: 8025
i am deciding between these two, kef x300a and behringer media 40 usb
eljr is offline
Reply 2-Channel Audio
