Too much dynamic range streaming movies - AVS Forum
Old 01-07-2015, 01:56 PM - Thread Starter
Liked: 0
I live with 2 other people and when I stream movies, the dialogue is too soft and the explosions too loud. How can I reduce the dynamic range?
gymmphynn is offline
Old 01-07-2015, 03:06 PM
FMW
FMW's Avatar
Quoted: 620 Post(s)
Liked: 912
Raise the volume of the center channel relative to the other channels (dialog) and reduce the overall volume. That's what I do.
FMW is online now
Old 01-07-2015, 06:08 PM
bluewizard's Avatar
Quoted: 418 Post(s)
Liked: 145
Most modern AV devices have some type of volume conpression. On my TV it is called SRS TruVolume. On some systems it is as simple are "Night Mode".
That is the purposes of these feature to allow the average level to be higher, while restricting or clamping down on Peak volume.
Steve/bluewizard
bluewizard is online now
Old 01-13-2015, 12:02 PM
wunderkind's Avatar
I am tickled by this response because it is posted in a 2-channel Audio section.
wunderkind is online now
Old 01-13-2015, 01:52 PM
crn3371's Avatar
Quoted: 84 Post(s)
Liked: 53
What equipment are you using?
crn3371 is offline
Old 01-13-2015, 02:30 PM
Ratman's Avatar
Quoted: 279 Post(s)
Liked: 333
If you are ticklish, challenge the poster why the question was asked here, not the responder for trying to help.
Do you have any suggestions?
Ratman is online now
Old 01-13-2015, 02:40 PM
noisebeam's Avatar
Quoted: 12 Post(s)
If you don't have compression built into receiver/amp and you have an analog source you could add a compressor.
Like the FMR RNC 1773, use it in supernice mode.
noisebeam is online now
Old 01-13-2015, 10:41 PM
Quoted: 298 Post(s)
Liked: 121
...but the typical AVR has no convenient place to insert such a thing. And it's two channels, not 5.1.
audio2xs is online now
Old 01-13-2015, 11:22 PM
bluewizard's Avatar
Quoted: 418 Post(s)
Liked: 145
The compression aspect can be in the TV. My TV has this - RSRTruVolume. Most TVs have Nite Mode. I suspect some BluRay have this feature.
No need to buy an AVR. Just understand the capabilities of the equipment you have.
Steve/bluewizard
Old 01-14-2015, 07:21 AM
noisebeam's Avatar
Quoted: 12 Post(s)
I thought it was clarified this is 2 channel. If an AVR is involved, then yes of course.
