Integrated recommendations w Paradigm - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-12-2015, 07:35 PM - Thread Starter
01svtL's Avatar
Quoted: 37 Post(s)
Hey guys, looking for some input. I am moving my MK9 se3's from a home theater setup into a dedicated 2 channel setup in my bedroom. I'm looking at integrated amps and DAC's, but am all over the place on what to get. I know the speakers are rated 15-200 watts at 93 db. My question is, will something like the Marantz PM6004 or 6005 with 45 watts/ch be enough to drive these at high volume for extended periods of time? By high volume, I mean at volumes that would be uncomfortable to stand directly in front of the speakers for longer than a few seconds. They are going in a fairly large room. Well, it's a long room, but only about 15' wide and the ceiling is only about 9 feet high. It's probably 25-30' long. I've read a couple of reviews that said the 6004 would shut off on them at higher volumes, but they didn't mention what speakers they were trying to drive.
I listen to mostly metal (newer stuff, not 80's "metal," so lots of fast double bass drums and electric guitar riffs - KSE, Periphery, After the Burial, Lamb of God etc) and found the Yamaha AVR to be a little harsh w the Paradigms.
I'm looking at units like the
-Onkyo a9050 (75w)
-Yamaha (as500) w an external DAC
-Marantz 6004 (45w) with an external DAC (POSSIBLY the 6005, but for just a little more money I can get a used 6004 and a better external DAC: grant fidelity, arcam etc)
-another option is using the Marantz na7004 as the DAC and preamp and connecting a budget power amp of some kind to it - Onkyo has a 75w power amp on Amazon w good reviews for $300.
Anyway, suggestions? Anyone here have these Paradigms that can make an experienced recommendation?
01svtL is offline
post #2 of 6 Old 01-15-2015, 12:08 PM
JA Fant's Avatar
Quoted: 231 Post(s)
Liked: 321
01svtl-
which brands/models have you auditioned? Your speakers will be easy to drive- question is, how loud do you want to play them?
JA Fant is offline
post #3 of 6 Old 01-17-2015, 10:36 AM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
-Onkyo a9050 (75w)
To my ears, the sound quality of the Onkyo and Yamaha is totally harsh and unacceptable; I would never recommend them. Marantz is considerably better from my listening experience.
The Music Hall 15.3, however, is an excellent-sounding amplifier for only $549, and it will give you the power you need with speakers rated for 93 db/watt. I recommend it.
The Audioengine D1 DAC is very good, and only $169.
commsysman is offline
post #4 of 6 Old 01-17-2015, 11:08 PM
Kpt_Krunch's Avatar
Here's a link that I found very useful when explaining amplifiers and how they work. It's explained over many posts and requires a bit of reading, but once you go through it all you should understand a lot better what you need for an amplifier.
"it's better to have it and not need it than to need it and not have it"
Kpt_Krunch is offline
post #5 of 6 Old 02-13-2015, 05:26 AM
eljr's Avatar
Quoted: 1050 Post(s)
Liked: 8025
Not likely.
I have to wonder, at the volumes you describe, if you will be able to stand those speakers at all.
eljr is offline
post #6 of 6 Old 02-13-2015, 10:11 AM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
-Onkyo a9050 (75w)
Get a NAD T758 receiver.
That will drive your speakers much better and sound nice.
Trying to solve your problem for $300 is like shopping for a new Porsche with a $5000 budget; lots of luck.
Any Yamaha or Onkyo amp you can buy for under $600 will suck.
The Marantz MM7025 amplifier is good.
Reply 2-Channel Audio
