Probably a Dumb Question re: Grado Wood Body Phono Cart. - AVS | Home Theater Discussions And Reviews
post #1 of 4 Unread Today, 10:24 AM - Thread Starter
roland6465's Avatar
So I just switched my Music Hall Magik 3 for a Grado Reference Platinum 1, and its output seems very low. With the MH, the volume display was usually in the -22 to -25db range. Now it's up in the 0 to +5db. I still have room to go louder, but after years of negative volumes, it's a bit unnerving.
Is this due to the wood vs. plastic body, just the way Grado is, or did I mess something up in the setup?
roland6465 is online now
post #2 of 4 Unread Today, 10:54 AM
crn3371's Avatar
Quoted: 89 Post(s)
Liked: 54
Go look up the specs of both cartridges. Simple answer is that most likely the Grado has a lower output. Really doubt you did anything wrong.
crn3371 is online now
post #3 of 4 Unread Today, 11:16 AM - Thread Starter
roland6465's Avatar
AHA! I was wrong, it's the Statement cartridge, and it has a .5mV output vs. the Magic 3's 3.0mV.
Thanks, I was going nuts!
post #4 of 4 Unread Today, 11:28 AM
crn3371's Avatar
Quoted: 89 Post(s)
Liked: 54
Time to go preamp shopping!
Reply 2-Channel Audio
