Turntable running slow and then stopping - AVS Forum | Home Theater Discussions And Reviews
Old 08-14-2015, 11:57 AM - Thread Starter
sathyans's Avatar
I have a Goldring turntable and recently have found it plays LPs much slower than it should. The music is obviously (sonically) dragging and eventually comes to a complete stop when playing at 33 1/3. While I have not been able to measure the speed, once the stylus goes down it starts to slow.
Is this something user serviceable/fixable? Can the motor be replaced?
While is hasn't had much use, the turntable is nearly 10 years old
thanks
Turntable: Goldring GR1
Cartridge: Goldring Elektra (MM)
Phono stage: Cambridge Audio 540P
Amp: NAD C 356BEE
Speakers: Wharfedale Diamond 8.2
sathyans is offline
Old 08-14-2015, 01:28 PM
Ratman's Avatar
Quoted: 1247 Post(s)
Liked: 1002
Try a new belt?
Ratman is offline
Old 08-14-2015, 02:24 PM
RayDunzl's Avatar
Quoted: 1228 Post(s)
Liked: 1428
Is the motor still turning when the platter stops??
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
Old 08-15-2015, 11:49 AM - Thread Starter
sathyans's Avatar
Yes, the motor is still running and the plastic bit onto which the belt is looped and is driven continues to revolve even after the platter and sub-platter stop. When the belt is looped onto 45 rpm rather than 33, the platter does not stop but the speed is not right for listening. I counted the rpms against a stopwatch: 43. When looped into 33, the platter slows and stops before I can really measure.
Could it be as simple as a belt change? Of course, I can't just pop into a local shop to get a replacement belt.
sathyans is offline
Old 08-15-2015, 12:53 PM
bluewizard's Avatar
Quoted: 1583 Post(s)
Liked: 914
Definitely a Belt, though a drop of oil on the turntable spindle mechanism would probably help too.
How old in the Turntable?
As far as Belts go, I have a turntable I bought in 1978, and I can still get belts for it.
Steve/bluewizard
bluewizard is offline
Old 08-15-2015, 01:27 PM
Ratman's Avatar
Liked: 1002
From the 1st post: While is hasn't had much use, the turntable is nearly 10 years old
http://www.analogueseduction.net/tur...able-belt.html
Ratman is offline
Old 08-15-2015, 03:20 PM
RayDunzl's Avatar
Liked: 1428
Is there a belt tension adjustment?
Is it level?
Maybe run it on 45 overnight to loosen things up if not used for a while.
http://ecom.armourhome.co.uk/files/g...tructionse.pdf
RayDunzl is offline
Old 08-16-2015, 02:47 AM
bluewizard's Avatar
Liked: 914
One of the worst things you can do to a turntable is not use it. The belts get dry and stiff, and hold their shape, which is not conducive to moving.
http://www.lpgear.com/category/GOLDRGB.html
Also from disuse the oil on the bearings on the motor and the spindle can dry out. I've had good luck loosening them up with Isopropyl Alcohol, then a few drops of light oil (sewing machine oil, 3-n-1 oil, or similar).
Steve/bluewizard
Old 08-18-2015, 02:27 PM
Supertaint's Avatar
I had the same issue with my old Rega. I swapped out the belt and it was fine after that.
2 Channel
Rogue Audio Cronus Magnum, Dynaudio Confidence C1, Clearaudio Performance DC, Clearaudio Maestro V2, Lehmann Silver Cube
Supertaint is offline
turntable
