2.1 Help needed. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By gajCA
post #1 of 7 Old 06-26-2016, 05:49 PM - Thread Starter
Quoted: 474 Post(s)
Liked: 185
2.1 Help needed.
I am putting together a Home Theatre system but currently only have a 2.1 setup. I will eventually have a 3.2 and than onto 5.2 but will always use 2.1 for music.
I know that the best quality sound comes from CD's and some vinyls. However I do not know what players and what else is needed. I have Ascend Sierra 2's hooked up to a Denon x4200w. Is that a good enough amp to run the speakers in a 2.1 setup?
What CD player is needed to get the lossless sound? Currently only have an xbox to play my movies and cd's but will buying an Oppo 4k player soon.
DO i need a seperate CD player? Do I need to run a seperate amp to my speakers?
Theriddler07sms is offline
post #2 of 7 Old 06-26-2016, 07:43 PM
grasshoppers's Avatar
Quoted: 861 Post(s)
Liked: 562
IMHO- you don't need a seperate amp for those speakers.
For now your Xbox will work fine as a CD player until
You get the Oppo. (Also a very good CD player) You don't
Need a seperate CD player. Also all CD's are lossless.
What subwoofer are you running in your 2.1 system??
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is offline
post #3 of 7 Old 06-26-2016, 07:55 PM
Knucklehead90's Avatar
Quoted: 504 Post(s)
Liked: 435
The Denon AVR should have enough power to drive your speakers unless you like to rock out with the volume way up. Unless you're driving the Denon into clipping you should be fine with the internal amps in the Denon. Clipping isn't good for the AVR but can be worse on the speakers since they are getting a distorted signal which heats the voice coils and can cause one or more of the drivers to fail - usually a tweeter will be the 'canary' that something is wrong.
Adding a sub will alleviate the power needed by the AVR since you now have the sub doing the low frequency work. Generally speaking the lower the frequencies the more power that is required to maintain the listening level you've selected. A sub set at 80-100hz via the AVR's crossover points usually will not be localized - the higher the frequencies the sub is made to reproduce the more localized the sound from it becomes. I can locate sounds coming from a sub at around 120-150hz. You can experiment by cutting off the R/L speakers and listen for sound from the sub. Some people can locate a sub playing frequencies as low as 100hz - according to them. Set it at 60-80hz crossover with the main L/R speakers in the AVR and you should be good to go.
External amps are fun to play with - and of course many of them have fancy lights and and a few have great big meters (ohhh -ahhh!) but external amps aren't really needed unless you're going to play music so loud that clipping/distortion is heard. I've always preferred external amps - I don't even have an AVR or preamp/processor but I have 4 external 2 channel amps. My Oppo 103 has 7.1 analog RCA jacks and has volume control for the analog outputs - it does not have volume control for digital output. I don't watch many movies but I have 5.1 for those times that I do and all 5 of those channels have an external amp driving the speakers. Normal mode is 2 channel.
I'd venture to say that there are many more DVD & Blu Ray players playing CD's than there are CD players playing CD's - that includes my setup. Your Denon has some pretty decent DAC's built in - I'd run an optical or coax from your current DVD/Blu Ray player and see how well it performs. You might also try the analog outputs from that player to the Denon's analog inputs to see if you hear a difference. You will be comparing the DAC in your player vs the DAC in the Denon.
Yamaha CX-A5000 - VTA ST-120 (6550 output tubes) - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - Acurus A100 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #4 of 7 Old 06-26-2016, 08:03 PM - Thread Starter
Quoted: 474 Post(s)
Liked: 185
I have 2 Reaction Audio Gamma 15's on order (getting amps switched before they ship, the rest is ready to go)
Thank you for the info. I have my current cheap JBL sub crossed over around 80Hz and my Sierra 2's set up as small speakers. I currently only have my xbox for CD player Until I buy the Oppo, does optical out sound better than HDMI?
post #5 of 7 Old 06-27-2016, 09:04 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Hope you receive them in a timely manner. In the last couple of months, RA has been plagued with very delayed ship dates and also problems with refunding people's money when orders are cancelled.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #6 of 7 Old 06-27-2016, 10:57 AM
gajCA's Avatar
Quoted: 4298 Post(s)
Liked: 2753
IMHO wait on the Oppo and use your Xbox for CD's as the weakest link seems to be the sub.
I'd get a servo sub for music; Rhythmik is the best bang/buck servo out there and they offer sealed as well as ported versions.
cel4145 likes this.
gajCA is offline
post #7 of 7 Old 07-19-2016, 07:11 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
The OPPO BDP-103 is a very good universal player with tons of features, and it sells for $499. Highly recommended.
commsysman is offline
Reply 2-Channel Audio
