2.1 for PC - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Knucklehead90
post #1 of 4 Old 07-14-2017, 04:23 PM - Thread Starter
petriebird's Avatar
2.1 for PC
I have been slowly working on my ultimate desk setup for my PC's and have decided that my new project would be audio. I saw a video that detailed a pair of polk audio bookshelves and a stereo amplifier while giving a compact amp as a possibility. I wanted to see if I can get some advice on selecting a compact 2.1 amplifier. My HT setup is Denon and klipsch vf-36 filled out to 5.1 I have wanted to try out some other brands for a while so recommendations would be appreciated. I was currently looking at a max budget of $250 w/o subwoofer (but it can go up if needed). Are there any quality compact amp's or should I just find a cheap stereo amp?
Follow up thought, I have always wanted to go the amp/pre-amp route just to see what it's all about and maybe this could be a starting point. I could start cheap and when I want to upgrade I can give this to my blind friend who I need to get PC speakers for anyways.
edit: I have been looking around and found a pyle and an audiosource 2 channel amp and I'll worry about the sub later. Thoughts? Also I ran across some tube amp's and I'm so intrigued. I'm going to guess that they don't fit into a desktop PC and probably aren't that durable not to mention I'm sure the cheap ones aren't that great, but I think it's really cool. Gonna do a little looking around just out of curiosity.
petriebird is offline
post #2 of 4 Old 07-15-2017, 09:13 AM
Quoted: 32 Post(s)
Liked: 973
I have a Altec Lansing computer speaker set hooked up For me at near field it sounds surprisingly good. XA 2021 Over my right shoulder is my vinyl setup tho. YMMV
leecreek is online now
post #3 of 4 Old 07-15-2017, 11:32 AM - Thread Starter
petriebird's Avatar
Ok I went with an SMSL SA-160 and a pair of Polk TSi-100. I didn't really know what I was looking at so I just went with my gut and budget. Hopefully this will be a good start in stereo audio.
post #4 of 4 Old 07-16-2017, 11:40 AM
Knucklehead90's Avatar
Quoted: 504 Post(s)
Liked: 435
A good start, yes. You might want to consider adding a small sub to that setup. The Polks play down to 61hz according to Polk Audio. You'll be missing an octave or so of low end sound without a sub. You'll need a sub with speaker level inputs since your amp has speaker level output only. A small sub that is getting a lot of attention lately is the Emotiva BasX 8" sub. It plays down to 28hz +/- 3db. Plenty low for most all music.
petriebird likes this.
Yamaha CX-A5000 - VTA ST-120 (6550 output tubes) - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - Acurus A100 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
Reply 2-Channel Audio
