Oppo Sonica and Turntables - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-12-2017, 04:50 PM - Thread Starter
jilgiljongiljing's Avatar
Quoted: 16 Post(s)
Hi all,
I just picked up the Sonica to try it out, I already have a BDP-105, I figured I'd do some A/B comparisons and keep the Sonica if it offers improvements. Current setup is Oppo BDP-105 & Rega RP3 -> Rotel pre amp -> Rotel 1590 power amp.
Added bonus is having the dac/hdd local to the room I currently run a LONG balanced cable from my dedicated HT room to my music room and share the BDP-105 for bluray and 2ch audio duties.
For the RP3 I have a Rega Phono stage going to aux in of the Rotel and then Balanced to the power amp. Input switching and volume is done by the Rotel pre currently.
It looks like my best bet is to connect the Sonica directly to the 1590 power amplifier using balanced cables as that would give the cleanest signal path and the best utility value for the Sonica. Problem is, what do I do with the Rega? It looks like the AUX input on the Sonica re-digitizes the signal and decodes it again to send out the balanced out (WHY???) so its really not ideal for the Rega Phono to go into this AUX (Oppo even says so in the Manual oddly enough, yet they provided a ground on the Sonica, its sort of conflicting).
I will try it out however and A/b test between the Rotel pre and Sonica Aux to see if there is degradation but clearly digitizing the lovely analog output isn't very exciting to hear.
One option is to connect the Rotel Pre to RCA on the 1590 and Sonica to balanced input and manually switch between the inputs on the power amplifier (not ideal at all since my power amp is a monster and the rear is not easily accessible.
Obvious Option B is to route the Sonica to Balanced inputs on the Rotel Pre and then to power but I'd essentially have two pre-amps in the path in this case.
Am I missing something or has the Sonica shutdown all vinyl lovers
jilgiljongiljing is offline
post #2 of 3 Old 10-14-2017, 06:17 AM
canyoncreek's Avatar
Quoted: 45 Post(s)
Liked: 51
Originally Posted by jilgiljongiljing View Post
Hi all,
I use my xsp-1 in the same way. I tried Sonica as pre, but liked the xsp better. Just set Sonics to 100 and disable volume, now just a nice steaming dac
Sent from my SM-G955U using Tapatalk
canyoncreek is offline
post #3 of 3 Old 10-16-2017, 10:44 AM - Thread Starter
Quoted: 16 Post(s)
Oh well, I've decided to figure out a way to switch the inputs on the power amp instead.
The Sonica just sounds the best when connected directly to the power amp without the Rotel Pre in the way (maybe its placebo, maybe its not, but I swear it sounds cleaner and tighter and the Rotel is "smoothening" the sound a bit overall)
So I've re-arranged my shelves to give me enough room to switch the inputs on the back of the power amp as needed. Problem is I currently do not have a way of connecting the Rega to the 1590 without the Pre. I would prefer to remove the Rotel pre altogether and get a simple single input pre or a Phono with volume control.
I guess a new thread is in order.
Thanks for the comment though
Reply 2-Channel Audio
