Getting my Sub to work with 2 channel PCM Stereo (Yamaha RX-v657) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-06-2007, 02:46 PM - Thread Starter
noirs's Avatar
Hi, I have a Yamaha RX-V657 receiver, with a center channel, front left+right, surround left+right and sub hooked up.
When I watch DTS or Dolby Digital movies the subwoofer does its thing, its awesome.
However, when I play music from my media center, which comes in as 2 channel stereo (PCM) over S/PDIF, the sub doesn't do anything.
If I put the amp in 'straight' mode, I only hear sound out of the front left+right speakers. However, if I put it in standard-surround, or 7-channel-stereo, then I hear music out of the surround speakers and the center channel, but not the sub.
Any ideas?
thx
- Alex
noirs is offline
post #2 of 3 Old 01-06-2007, 06:13 PM
SomeCiscoGuy's Avatar
Please check your speaker settings on your Yammy - if they are set to large, then the sub-woofer out is most likely not sending a signal as your Yammy thinks your FL/FR speakers are full range. The other item to check is if you have an "enhanced bass" or "bass boost" setting that will send the low frequency signal to your FL/FR+Sub at the same time.
Hope this helps
SCG
SomeCiscoGuy is offline
post #3 of 3 Old 01-07-2007, 03:36 PM - Thread Starter
noirs's Avatar
Thanks SCG, I got it working. The BASS OUT was set to FRONT i think, I changed it to BOTH (other optino was SWFR), now the sub works.
noirs is offline
Reply 2-Channel Audio
