Six speakers and 2 channels - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-26-2007, 10:37 AM - Thread Starter
Dadillac's Avatar
I have an old stereo amp that I am using for my TV sound system. I have my "A" channel into a set of Polk M20's. I also have my "B" channel into a set of passive subs. It sounds good, but I want to add a third set of speaks. Since I do not want to drop below 8 ohms, I have an issue. I have added the third set of speaks in series with the subs, and it is weak as hell being 16 ohms. Is it possible to hook two speakers up in series/parallel? If I run the + out of the amp into the + on the speaker, the - out of the speaker into the + of the sub, and the - out of the sub into the amp, I get series. Can I keep that, but run two more wires from speaker + and -, into the + and - of the sub? Will that blow the amp to pieces, or will it result in an 8 ohm resistance? Please help.
Don
Dadillac is offline
post #2 of 8 Old 02-26-2007, 12:21 PM
trekguy's Avatar
Originally Posted by Dadillac View Post
I run the + out of the amp into the + on the speaker, the - out of the speaker into the + of the sub, and the - out of the sub into the amp, I get series. Can I keep that, but run two more wires from speaker + and -, into the + and - of the sub? .
Don
Any two speakers can only be connected in one or the other configuration; series or parallel.
If you connect 3 spkrs on each side you get more choices by using a serries/parallel combination. Two in serries to get 16 ohms and connect that pair in parallel with the third.
1/Rt =1/16 + 1/8
1/Rt = 3/16
Rt = 5.3 ohms
If your speakers are all of different design it is possible that the individual impedance curves will combine at some frequencies to either greatly raise or lower the momentary impedance. So if you try this go easy on the gain at first.
Or you can buy or make an impedance matching speaker switch designed to work with amps that cannot drive low impedance loads.
The fact that an opinion has been widely held is no evidence whatever that it is not utterly absurd.
-Bertrand Russell
trekguy is offline
post #3 of 8 Old 02-26-2007, 04:24 PM - Thread Starter
Dadillac's Avatar
So there isn't a way to have two 8 ohm speakers running off the same channel to stay at 8 ohms? Thats a bummer.
Don
Dadillac is offline
post #4 of 8 Old 02-26-2007, 04:36 PM
mastarecoil's Avatar
If you had four 8 ohm speakers you could get it down to 8 ohm.
mastarecoil is offline
post #5 of 8 Old 02-26-2007, 05:12 PM
trekguy's Avatar
Don
Are you certain that your amp won't drive a reduced impedance? Many units will handle 5 ohms without over heating.
If it just won't do it you can put a heavy duty resistor, like this $.69, 8 ohm 20 watt wire wound from Parts Express in place of a fourth speaker.
That would give you [two speakers in parallel for 4 ohms] connected in series with [one speaker and the resistor in parallel for 4 ohms].
-Bertrand Russell
trekguy is offline
post #6 of 8 Old 06-07-2007, 08:49 AM
OneEyedJack's Avatar
Trekguy: Would it? Are speaker ohms measured as impedances or resistances?
OneEyedJack is offline
post #7 of 8 Old 06-07-2007, 02:59 PM
sivadselim's Avatar
Quoted: 270 Post(s)
Liked: 227
I have my "A" channel into a set of Polk M20's. I also have my "B" channel into a set of passive subs. ...............I do not want to drop below 8 ohms,...............
Unless the "A" and "B" channels represent 4 separate amps instead of 2 (1 right, 1 left), you're already below 8 Ohms.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #8 of 8 Old 06-07-2007, 03:18 PM
augerpro's Avatar
Quoted: 137 Post(s)
Liked: 68
I agree. Most A/B setups are just one channel (amp) with each speaker running parallel. Assuming the Polks and the sub are 8 Ohm, you're already at 4 Ohm nominal now. I would advise against using a resistor because 1) it must be rated for the highest power teh speakers could see, 2) it'll just be sink for the amp, 3) it'll get hot as hell, 4) it's just not a good solution.
You're asking too much from that amp. You need to decide what your needs are and buy amplification according to that.
augerpro is offline
Reply 2-Channel Audio
