2 channel stereo to 5.1 surround - AVS Forum
post #1 of 8 Old 04-07-2007, 07:28 PM - Thread Starter
johnson636's Avatar
Does anyone know if you can convert 2 channel stereo to 5.1 surround sound?
johnson636 is offline
post #2 of 8 Old 04-07-2007, 07:47 PM
sivadselim's Avatar
Quoted: 36 Post(s)
Liked: 62
Be more specific about what you're trying to do, exactly.
With the proper reciever or pre/pro you can "convert" 2-channel stereo to non-discrete 5 channel sound with Dolby Pro Logic II.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is online now
post #3 of 8 Old 04-07-2007, 08:47 PM - Thread Starter
johnson636's Avatar
Thanx.
post #4 of 8 Old 04-09-2007, 12:08 PM
Tnilsson's Avatar
Liked: 24
Yes, you can. Your receiver or processor should already do that. Or you can buy an external processor to do it. Some do it better than others. I have an external Technics processor for DTS and an EFE processor for converting mono or stereo tracks to 5.1 (the best I have ever heard for making music sound like you are actually at a live performance and a component I can never imagine giving up).
Tnilsson is offline
post #5 of 8 Old 09-25-2007, 08:26 AM
gregf70's Avatar
Hello, I have the Onkyo TX-SR505
This is what the website shows..
DOLBY Decoder - PLIIx, DD, DD-EX
DTS Decoder - DTS, ES, NEO6, 96/24
So If I have this correct and I put in "any old normal cd" and I put my reciever on PLIIx it should utilize all the 5.1 system? I know, not discretely, meaning all the speakers will play the same thing..I guess, or does that mean that it will still split the left and rights for both front and rears and the bass will come out of the sub?
Is that correct?
Is DD, or DD-EX any better? or the DTS side? I am thinking I have to buy specialized DTS music to play on that side. But the DTS side will discretely seperate all the channels as they were set up by the recording engineer?
Thanks for clarification.
gregf70 is offline
post #6 of 8 Old 09-25-2007, 01:03 PM
vinipux77's Avatar
Greg,
Your receiver can use the PLIIx or Neo6 or any of Onkyo DSP modes to create surround ambiance from "any old normal CD" or other 2-channel source. Check the manual (I remember mine had something towards the end) for a description of each and recommendations which ones to use. Obviously "Movie" and "Cinema" work better for dialog-type content, and "Music" for everything else.
You'll find that for depending on content and even your mood you'll like some better than others. I use "all channel stereo" for background listening, for example.
Also, unless you play 'direct' mode, some sound should be sent to your sub even in stereo if you set front speakers to 'small'.
Enjoy the hobby!
- Val
vinipux77 is offline
post #7 of 8 Old 09-25-2007, 05:10 PM
broadwayron's Avatar
I know my old Harman Kardon receiver could convert 2 channels into 5.1 or 7.1 (I think). I thought it sounded like crap, though. Actually, I eventually reverted back to just plain stereo sound, and like it much better than the processed junk. Disclaimer - I only listen to music (no home theater).
broadwayron is offline
post #8 of 8 Old 09-25-2007, 06:40 PM
Kal Rubinson's Avatar
Quoted: 31 Post(s)
Liked: 117
You can synthesize 5.1 surround from 2 channel but the results are variable. Some processes for doing this are better than others and some people are more satisfied by them than are others.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
Reply 2 Channel Audio
User Tag List
