Using RCA Cables for Receiver and Balanced for 2 channel Tube preamp to amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-22-2007, 06:23 PM
B&W700guy's Avatar
Looking at buying McIntosh C2200, 2 channel Tube Preamp. I own a Sunfire GTA5200 amp. The amp has Balanced and RCA inputs. My A/V Receiver is connected to the amp via RCA. I want to connect the McIntosh via Balanced connections. Looked through the manual there is no mention that you can't do it, furthermore there is no toggle switch for going from RCA to Balanced.
Is anyone doing what I just explained?
Thoughts....
B&W700guy is offline
post #2 of 5 Old 04-28-2007, 10:45 AM
B&W700guy's Avatar
post #3 of 5 Old 04-28-2007, 12:24 PM
speco2003's Avatar
If the preamp and amp have XLR ins then just use them. There is usually not a switch to toggle.
speco2003 is offline
post #4 of 5 Old 04-28-2007, 12:34 PM
yatchaks's Avatar
I pretty sure you can't. If you attempt to connect RCA and XLR, for safety, one connection will be shut down. If I remember correctly, you will lose the XLR connection.
You can use the tube to drive the mains at all times, although you may not want to use this option since this will certainly decrease the life of the tubes, and I assume you only want to listen to the tubes while listening to two channel music.
Perhaps someone may chime in and tell us if an external HT bypass would be an option. Some tubes have a HT bypass built in, I don't know if a stand alone is sold.
Mark
I contend that we are both atheists. I just believe in one fewer god than you do. When you understand why you dismiss all the other possible gods, you will understand why I dismiss yours." - - Stephen Roberts
yatchaks is offline
post #5 of 5 Old 04-29-2007, 01:23 PM
musicman07's Avatar
You can use XLR on one channel and RCA on another, but you cannot use both on the same channel.
musicman07 is offline
Reply 2-Channel Audio
