Should seperates be from the same make? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-08-2007, 10:52 AM - Thread Starter
Doc99's Avatar
I was wondering what sonically happens when you combine a preamp and power amp from 2 different manufactures? For instance, I have a Rotel preamp, and naturally was going to buy the matching power amp, but found a good deal on a NAD power amp. Which will be the predominant component-in other words...will my system have the NAD sound or sound like the Rotel? I always thought that the Power amp section is what gives the sonic character, and the preamp is just really a source selector, and volumn control. Would it just be better to match the pre/Pwr amps from the same company?
Doc99 is offline
post #2 of 10 Old 06-08-2007, 08:25 PM
oztech's Avatar
Liked: 101
it was done for years in the 60's and 70's what ever fit your needs and budget for a pre amp
and generally two mono blocks of considerable quality.
oztech is offline
post #3 of 10 Old 06-08-2007, 08:28 PM
crackyflipside's Avatar
Is there any chance you can audition both and decide for yourself?
crackyflipside is offline
post #4 of 10 Old 06-08-2007, 09:03 PM - Thread Starter
Doc99's Avatar
No. That is why I was asking here, to be informed before I make a purchase.
Doc99 is offline
post #5 of 10 Old 06-08-2007, 09:30 PM
swwg's Avatar
I think it should be okay to mix and match but be aware of the 2-prong vs 3-prong plugs. They have very different signal grounds that can potentially cause hum and noise and cancel out the advantage of balanced connections.
swwg is offline
post #6 of 10 Old 06-09-2007, 03:24 PM
Shizelbs's Avatar
Its more than okay to mix and match brands. I do it. Both the preamp and amp will impact and affect sonic characteristics.
XBox - Shizelbs
Shizelbs is offline
post #7 of 10 Old 06-09-2007, 07:42 PM
Dave928's Avatar
Location: Seattle - it's not Hell, but you can see it from h
use what you like...
No, i can't go out, i'm watching Garbo...
Dave928 is offline
post #8 of 10 Old 06-12-2007, 04:28 PM
hifiskipper's Avatar
The Rotel and NAD are VERY comparable. I've listened to both and can hear very little if any difference
hifiskipper is offline
post #9 of 10 Old 06-12-2007, 06:10 PM
whoaru99's Avatar
Liked: 69
Mixing and matching is one of the best reasons to go separates. You can choose what you think is best/right for the job.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #10 of 10 Old 06-13-2007, 05:22 PM
Jonomega's Avatar
part of the idea of going with separates is that it gives you the ability to mix and match. Perhaps you need a lot of power, but like tube sound, you could mix a tube preamp with a solid-state power amp.
Jonomega is offline
Reply 2-Channel Audio
