Reciever/Amp for an inexpesnsive 2.0 setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 06-12-2007, 11:25 PM - Thread Starter
Chu
Chu's Avatar
Hello all. I've been wanting to put together a good 2.0 system for my living room for a while. I had a ceiling of $500, but then the Energy RC-30 (Info, specs linked from page) for $200/ea. deal was just too good to resist.
So now I have a great set of speakers, but only $100 or so to work with for a receiver/amp to go with them.
Scrounging up all that I can, I can go to $200 max. At this price point, what sort of receivers or amps would go well with the speakers I have? Any popular used units to specifically keep an eye out for? I assume I don't have too many choices on this sort of budget
Chu is offline
post #2 of 21 Old 06-13-2007, 12:41 AM - Thread Starter
Chu
Chu's Avatar
Ok to answer my own question . . .
After some research it looks like there are exactly two integrated amps out there that meet my critera. The Pioneer A-35R and the Super T-Amp. Same price as well, though the specs on the A-35R look a bit better.
Is this really all there is?
Also, another question. I understand Integrated Amp = Preamp + Power Amp. Power Amp = the actual amplification stage. So what exactly is a preamp besides a fancy volume control? With a good source, is it possible to skip the preamp stage and simply feed the power amp directly?
Chu is offline
post #3 of 21 Old 06-13-2007, 01:27 AM
briankmonkey's Avatar
I picked up a TSXR 604 at Fry's for $255 and it drives my RC-30's pretty well IMO.
I've had my RC-30's on a older receiver with less power and it didn't sound as full in the midrange and as tight in the bass, so I'd make sure you get some decent power to them.
You are going to love the RC-30's though, they rock. FYI, they may need a little break in time (basically sound a little smoother after 100-200 hours from what I was told).
briankmonkey is offline
post #4 of 21 Old 06-13-2007, 04:53 AM - Thread Starter
Chu
Chu's Avatar
Thanks for the response again, I will defiantly check some local sources and see what comes up vs. online.
I spent some more time researching on these fourms and elsewhere, and seem to have come up with some answers . . . and some more questions. Basically, at this price range the realms of integrated amps and receivers are merged.
1. "Integrated Amplifiers"
The two key players here are the Super T-Amp and the Pioneer A-35R. They are priced almost exactly the same, however the Pioneer has better specs at 45W/channel @ 8 ohm. The T-Amp is a class T amp, and the Pioneer . . . isn't. I really don't know what the topography is.
Super T-Amp
Pioneer A-35R
Now, the big question. Am I missing something with these? The Pioneer has much better specs, and from searching ahas garnered some good reviews, and is the same price as the competitor . . . but the T-amp gets all the attention. Why? Is there something not in the specs that I am missing?
2. Recievers
After a lot of research, in my price range ($200 ish) there is really only one receiver that looks attractive, the Panasonic SA-XR55. According to the AVSforum thread, the sound quality is great in 2.0 mode, and it will use both dual and bi-amp mode at the same time to get up to 100W/ch.
Panasonic SA-XR55S
So, we have two more questions . . .
1. The receiver is essentially a class-T amp. It's $25 more then the super T-Amp and puts out 80W/ch. more. hrmmmmm . . .
2. It's incredibly hard to find any comparison between the SA-XR55 and the A-35R, even though all sub-$200 roads seem to lead to one of the three referenced amps. While the XR55 puts out twice the power, the Pioneer Elite series has a reputation for great sound quality, and I am going to guess "great" in the integrated amp world and "great" in the receiver world are very very different things.
Also I find allegations everywhere that companies play fast and loose with their wattage ratings at this price point, so we have yet another layer of ambiguity.
Any thoughts? Maybe answers
Chu is offline
post #5 of 21 Old 06-13-2007, 06:59 AM
Iostream's Avatar
Quoted: 34 Post(s)
You might look at the HK 3480 refurb units. 120WPC stereo receivers. Right at $200 refurbished. You could probably pick up a used one for slightly less than that even.
Mastering and 2 Channel: Wavelab 9/Bluesound Node/Pro-ject RPM 5.1 SE -> McIntosh C47 -> McIntosh MC452 -> Focal Sopra No 2 and REL S5/SHO (switchable)
Mixing and desktop: Cubase/Squeezebox -> Oppo HA-1 -> Rotel RB-1080 -> B&W N805 and REL S2
Theater: Oppo 103d -> Marantz SR7009 -> Martin Logan Motion 4/8 7.1 with REL S5/SHO
Living Room: Marantz SR5009 -> Rotel RB-993 -> B&W N804/HTM1 Rythmik F12SE
Iostream is offline
post #6 of 21 Old 06-13-2007, 08:20 AM
Gaara's Avatar
Don't forget about the Trends unit, I bought a TA-10.1 to replace my Super-T amp and it was a decent improvement for about the same price. StereoMojo did a shootout among integrated chip type amps and the Trends came out the winner.
Jared
Gaara is offline
post #7 of 21 Old 06-13-2007, 01:12 PM
Russdawg's Avatar
With only two bills I'd get the Panasonic......great SQ for the money.
Russ
Russdawg is offline
post #8 of 21 Old 06-14-2007, 08:09 AM - Thread Starter
Chu
Chu's Avatar
Thanks for the replies, they've helped a lot.
Right now, I can get a HK3480 or a Panasonic SA-XR55 for pretty much the exact same price.
Has anyone heard both of them and can comment on the sound quality? Also, the "VMAx" processing on the H-K unit is plastered all over their marketing material, does it really do anything worthwhile?
Chu is offline
post #9 of 21 Old 06-14-2007, 08:35 AM
Iostream's Avatar
Quoted: 34 Post(s)
I would have to say the V-Max bit on the HK unit is marketing mess... I have only turned it on long enough to realize that it should be left off I haven't heard the Panasonic.
Iostream is offline
post #10 of 21 Old 06-14-2007, 11:08 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 286 Post(s)
Liked: 4073
I'd go used here or Audiogon. Much more bang for the buck.
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
post #11 of 21 Old 06-14-2007, 11:16 AM
Ron Temple's Avatar
Quoted: 163 Post(s)
Liked: 133
I'll 2nd or 3rd the HK...some friends are very pleased with it's performance driving demanding speakers...the power is right and it has pre-outs and phono inputs.
I don't lurk as much as I used to and I NEVER listen. Comes from being old and cynical.
Ron Temple is offline
post #12 of 21 Old 06-14-2007, 11:30 AM
ematcion's Avatar
Quoted: 84 Post(s)
Liked: 121
You are missing out on the 2 channel stereo receivers from Onkyo, the TX-8222 (50 watts/channel) and the TX-8522 (100 watts/channel). Super smooth sound with plenty of power. Of all the amps/receivers mentioned so far, the Onkyo receivers and the Pioneer amp would be my choice.
Avatar - My guard dog, Bogi
Part of my ever-growing SACD collection
ematcion is offline
post #13 of 21 Old 06-14-2007, 11:42 AM
lastplace's Avatar
Quoted: 33 Post(s)
check out your local craigslist.org , there are some great deals
I love this HD stuff!
lastplace is offline
post #14 of 21 Old 06-14-2007, 01:09 PM
Lindahl's Avatar
Quoted: 24 Post(s)
Yeah, in my area there's a Musical Fidelity A3 integrated on craigslist for $350! There's also a Denon PM2000R integrated, which has received excellent reviews, for around $400. When you find audiophile products there, you can generally get a better deal than audiogon.
Lindahl is offline
post #15 of 21 Old 06-14-2007, 05:58 PM
oldschool4life's Avatar
Isn't that Denon $1200???
Originally Posted by oink
Mr. Cialella is, without question, the AVS honorary MOST ADMIRED PERSON OF THE YEAR.:D
oldschool4life is offline
post #16 of 21 Old 06-14-2007, 08:09 PM
Lindahl's Avatar
Quoted: 24 Post(s)
Yup... I'm tempted, but it says sale pending, and my wife would kill me (I just recently bought a Sonos bundle).
Lindahl is offline
post #17 of 21 Old 06-14-2007, 09:31 PM
When I sell my Pioneer Elite integrated amp (the A-35R), I'm considering the Denon integrated, a Cambridge Audio integrated, or another option around that price point...
...or, perhaps Rotel seperates.
post #18 of 21 Old 06-15-2007, 07:11 AM
cdnewmanpac's Avatar
Rotel used to make a 30watt/channel integrated that retailed around $300 (rbx930?). I see it pop up on audiogon periodically for 100-150. This is a great little amp. I had one for several years and could easily drive my paradigm phantoms to decent levels in a modest (12x15) room. It won't fill a huge room and got a bit overwhelmed by mahler, but handled rocknjazznpop just fine.
cdnewmanpac is offline
post #19 of 21 Old 06-15-2007, 01:39 PM
Raymond Leggs's Avatar
What about that little $35.00 T-Amp?
Raymond Leggs is offline
post #20 of 21 Old 06-16-2007, 03:47 AM
Euro series...
One model had a remote; the other didn't.
post #21 of 21 Old 06-16-2007, 10:51 AM
doubleroll's Avatar
look for a used Linn Majik integrated. I had one for a while, it was awesome.
doubleroll is offline
Reply 2-Channel Audio
