Comparison on Compression - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-16-2007, 02:12 AM - Thread Starter
CHRIS650's Avatar
I mostly listen to classical music, so require pretty sound fidelity.
I have a computer runing iTunes shooting digital pcm through usb to a very good receiver.
Has anyone experienced using compression file to enjoy high fidelity classical music? what are the comparison between, mp3 @320, aac @256 or 320, apple lossless? what which bitrate do you hear the difference for AAC or MP3?
CHRIS650 is offline
post #2 of 3 Old 08-16-2007, 02:43 AM
skromnibog's Avatar
I think you will find more about audio compression at http://www.hydrogenaudio.org/forums/index.php
There are listening tests conducted there which may help you in your choice. However, for your own preferences it is better to conduct a listening test yourself.
skromnibog is offline
post #3 of 3 Old 08-16-2007, 12:43 PM
sivadselim's Avatar
Quoted: 267 Post(s)
Liked: 224
If space (size) is not a concern, use a lossless format.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is online now
Reply 2-Channel Audio
