Would these speakers be pointless with this tv? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-12-2007, 06:06 PM - Thread Starter
Sephirothmoon's Avatar
So I have a sharp 42" hdtv with two speakers of 15 W each.
I want to buy these logitech 2.1 pc speakers: http://www.amazon.com/Logitech-2-Pie...9639251&sr=8-1
Since these are pc speakers, I have to hook them up through the headphone jack correct? Is this the adapter that I need?:
http://www.amazon.com/Monster-CableL...9639846&sr=8-1
2nd question:
The speakers are 6W each with 20W subwoofer.
Will this give any noticeable increase in sound quality. I know tv speakers in general suck, but the total W is not much higher, and I'm going through the headphone jack, then through the adapter - so is it worth it with these speakers, does the subwoofer make a big difference?
Sephirothmoon is offline
post #2 of 9 Old 09-12-2007, 06:07 PM - Thread Starter
post #3 of 9 Old 09-12-2007, 06:09 PM - Thread Starter
hmm, can seem to post the links for some reason.
the adapter is "Y-Adapter, 1/8 Mono Male to (2) RCA Female"
post #4 of 9 Old 09-12-2007, 07:02 PM
sivadselim's Avatar
Quoted: 114 Post(s)
Liked: 126
Yeah, Amazon links don't work.
Which Logitech speakers? If they're PC speakers, why do you need to convert the TV out to L/R RCA? The speakers should already have the correct headphone-type jack. The only thing you may want/need is a headphone extension cord.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #5 of 9 Old 09-12-2007, 07:14 PM - Thread Starter
yeah, for some reason, if I type the link, half of it gets cut off.
and thanks for the info.
it's the logitech x-230 2.1
do you think this will provide better sound?
post #6 of 9 Old 09-12-2007, 07:16 PM - Thread Starter
i thought the plug was for a pc, and a diff size than a headphone jack plug - which is why i thought the adapter was necessary.
post #7 of 9 Old 09-14-2007, 08:48 AM
PULLIAMM's Avatar
I was under the impression that PC speakers and TV speakers were pretty much in the same class, sound quality wise.
PULLIAMM is offline
post #8 of 9 Old 09-14-2007, 08:57 AM
vitaminc's Avatar
if its 2.1 speakers for pc, it will noticely improve your tv viewing experience.
Logitech's PC speakers have very noticable bass that is excellent for gaming, loud music and sometimes movies, despite my opinion that the bass too muddy/distorted for my own musical taste (mainly classical musics).
vitaminc is offline
post #9 of 9 Old 09-14-2007, 04:32 PM
Jonomega's Avatar
similar, except the pc speakers come with a subwoofer which grants the listener some value in 40-150hz frequencies. while the midrange and upper frequencies would be similar in quality, the absence of bass is not acceptable to most people, thus classifying the pc speakers as "much better" even though ~90% of the spectrum was there with the TV speakers.
Jonomega is offline
Reply 2-Channel Audio
