Max unbalanced distance? - AVS Forum | Home Theater Discussions And Reviews
Old 10-11-2007, 04:12 PM - Thread Starter
JRTame's Avatar
What has been everyones experience as far as the maximum distance one has run unbalanced audio over RG-59 or RG-6? I've heard of installations where one has run a dual coax up to @200' from a centralized audio processor to a local receiver. We're talking in situations where there was not a spare CAT5E to send balanced signals.
Might be a dumb question but would the shielding in the RG-6 Quad shield cable assist in reducing noise over a longer run?
Same question concerning component video. What has been everyones experience as far as the maximum distance sending component video over RG59? I've seen installations where the coax was run a little over 100'. RG-6 I've been told is not ideal due to the "skin effect".
JRTame is offline
Old 10-11-2007, 06:50 PM
ctviggen's Avatar
Quoted: 116 Post(s)
Liked: 32
RG59 and RG6 are basically created the same. They're a center conductor surrounded by an insulator, which is surrounded by a shield/conductor, and a jacket that surrounds the shield. If RG6 has the skin effect (an effect where conductive elements tend to travel on the surface of a conductor), then the RG59 would, too.
Bob
ctviggen is offline
