DIY Prismasonic Lens Bracket? - AVS Forum | Home Theater Discussions And Reviews
Old 02-25-2008, 09:56 PM - Thread Starter
mlbrand's Avatar
Anyone have any good ideas or pictures of a bracket I could make to mount my Prismasonic 1400 pass-through anamorphic lens to my projector/mount? I am moving from a shelf mounted projector and lens, to a celing mounted setup. BTW, I am setting this up for a Sony VW40 projector, with a Chief RPA-U mount.
mlbrand is offline
Old 02-26-2008, 03:23 PM
Gary Lightfoot's Avatar
Quoted: 599 Post(s)
Liked: 354
I used a piece of mdf to make my ceiling mount base, and then made an extended version to include the lens. I did need to move the mount as the lens changes the central balance point. There are a few pics in my link below.
Gary
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is offline
Old 02-26-2008, 04:34 PM
bgosselin's Avatar
If you are looking for a simple design.
I copied Tor Arne lens mount. Just a few $
bgosselin is offline
Old 02-26-2008, 05:04 PM - Thread Starter
mlbrand's Avatar
Gary
Gary,
Using a mdf/wood extended base is a good idea, and the change in balance is a good point. I use a lot of wood in my DIY projects, as I woodwork as a hobby. I am extending my projector mount down from the ceiling, so the wood base would have to be above the projector mount I'm thinking. Maybe like turning a shelf mount upside down and then attaching it to the extension pipe?
mlbrand is offline
Old 02-26-2008, 05:07 PM - Thread Starter
mlbrand's Avatar
I like simple, and that looks pretty good. Are those extensions made out of metal?
mlbrand is offline
Old 02-26-2008, 05:15 PM
Quoted: 599 Post(s)
Liked: 354
Does this pic help?:
http://uk.geocities.com/g.lightfoot@...ope/mount4.jpg
I used a speaker bracket as my mount and just extended the pole.
Gary
Old 02-26-2008, 05:45 PM - Thread Starter
mlbrand's Avatar
Gary
Oh yeah, that picture helps a lot, and gives me another idea and option to consider. Thanks!
mlbrand is offline
Old 02-26-2008, 06:12 PM
bgosselin's Avatar
Yes they are. I walk in home depot and search for the smallest but strong enough piece of metal that would do the job without bending. Cost me lest than 5$. I should paint it but prefer to watch movie instead.
