My CIH screen: 90", laminated, curved, AT. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-07-2008, 02:41 PM - Thread Starter
steadihd's Avatar
Hi I'm new to this forum since a couple of weeks and it inspired me to build myself a CIH 2.35 screen.
I build mine like "BungalowFilms" did with the lamination process.
Unfortunately I don't have pictures from the build but here are some of the screen en setup in my living room:
The prism are chrystal wedges I bought in Holland and they are 15 dollar each, and I must say they're not bad, with blu-ray the scharpnes will be much better then a stretched out DVD.
If there are any other questions, please let me know.
Hans Dijkman
steadihd is offline
post #2 of 5 Old 10-07-2008, 03:04 PM
applesandrice's Avatar
Hey, nice work! Enjoy!
applesandrice is offline
post #3 of 5 Old 10-08-2008, 07:50 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Very nice, good solution for the moving lens in and out.
oman321 is offline
post #4 of 5 Old 10-10-2008, 12:43 AM
dr.nop's Avatar
what kind of material you use for ATscreen
dr.nop is offline
post #5 of 5 Old 10-10-2008, 05:01 PM - Thread Starter
steadihd's Avatar
It s a real perforated vinyl like cinemascreen, I found it on a second hand site for about 150 dollars, it measured 16x6,5 feet and was taken from a closed cinema.
I just cut a piece from it that fitted my screen size.
Hans
steadihd is offline
Reply DIY Constant Height
