DIY CIH Projector with a fixed 2x lens? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-12-2009, 11:23 AM - Thread Starter
applesandrice's Avatar
Has anyone here tried building a projector with a 2x anamorphic lens as its primary lens? Couldn't somebody -- theoretically, at least -- build an LCD projector with a horizontal-stretch lens, and then control the aspect ratio with a scaler?
It seems to me like a reasonably sound idea, but I'm assuming there must be a good reason why I haven't seen it discussed already . . .
applesandrice is offline
post #2 of 3 Old 06-13-2009, 05:34 PM
Gary Lightfoot's Avatar
Quoted: 593 Post(s)
Liked: 349
The nearest I've seen to that was a Runco with a fixed prism lens on the front and the scaling options were built in. You just used the remote to select 16:9 or scope.
Still had a primary lens since this was just a 'standard' Runco pj with an A lens permanently attached.
What would be nice would be a pj with a 2.37 display panel rather than a 16:9 one and anamorphic lens.
Gary
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is online now
post #3 of 3 Old 07-13-2009, 09:01 PM
adude's Avatar
Quoted: 40 Post(s)
You can find lots of 2x anamorphic lenses on ebay and use those with 4:3 projectors. That will give you 2.66 max AR. Theoretically, it should work. The problem is almost all of the 2x anamorphic lenses are made for cinema projectors. Those are made to work with very long throws and have very small aperture. You may get vignetting.
Another option is to try 1.5x anamorphic lens with 16:9 projector and it will give the similar effect. There were some lenses like Iscorama 54 which had 54 mm dia at rear. That may work for home projectors.
adude is offline
Reply DIY Constant Height
