diy cylindrical anamorphic lens - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 05-02-2010, 06:33 AM - Thread Starter
dr.nop's Avatar
after long time finally my cylindrical anamorphic lens just finished
dr.nop is offline
post #2 of 23 Old 05-02-2010, 10:50 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Looks promising, any pics of it in action. Is it something that fellow DIY'ers can look into or are you looking to distribute the product. Details please
oman321 is offline
post #3 of 23 Old 05-02-2010, 05:18 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
This looks awesome. How does the astigmatism adjustment work?
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #4 of 23 Old 05-02-2010, 05:59 PM - Thread Starter
dr.nop's Avatar
adiust astigmatism by move posterior element it not easy like focus ring of shneider
but I think that adjust astigmatism is doing only at the first time we instal the lens .
Range of motion is about 1.4 cm is enough.
thank cavx
and screen shot will be here soon
dr.nop is offline
post #5 of 23 Old 05-02-2010, 06:08 PM - Thread Starter
dr.nop's Avatar
I 'm interesting in cih and diy the anamorphic lens for 2 years ago
start with 2 prism, and finally 4 element cylindrical lens
in this thread i only show about anamorphic lens design. and technical discussion.please do not ask about selling or price of the lens otherwise this thread will be lock
thank you for your comment
dr.nop is offline
post #6 of 23 Old 05-03-2010, 04:05 AM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
How deep is this lens?
What throw distances can this lens operate?
Mark Techer
CAVX is offline
post #7 of 23 Old 05-03-2010, 04:20 AM - Thread Starter
dr.nop's Avatar
12 cm deep
anterior diameter16 cm
work at throw ratio at least 1.5
but for my hometheater is TR2.0 will be exellent
dr.nop is offline
post #8 of 23 Old 05-03-2010, 05:53 AM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
Originally Posted by dr.nop View Post
12 cm deep
Interesting. Mine is 131mm deep (so 11mm deeper) and it works in perfect focus out to 6m. It works with TRs down to 1.4:1 (tested) and I believe 1.3:1, however after 6m I need a spacer plate to allow an increase to the spacing between the glass.
How wide is your screen?
Mark Techer
CAVX is offline
post #9 of 23 Old 05-03-2010, 06:21 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Looking foward to the pics dr.nop, no price talk I promise As a fellow DIY lens maker (although not even remotely close as sophisticated as you) I was hoping it would be something achievable by us daring DIY'ers.
Can't wait to see all you have to show us.
oman321 is offline
post #10 of 23 Old 05-03-2010, 07:40 AM - Thread Starter
dr.nop's Avatar
some screen shot take by hand no tripod. i'm not good in taking photograph just looking for fun
focus is edge to edge
no CA was seen.
dr.nop is offline
post #11 of 23 Old 05-03-2010, 07:55 AM
HogPilot's Avatar
Liked: 25
Cool lens! It looks like the front elements are squared off rather than round like your rear element, I'm guessing to save money on extra glass that would go unused anyways. If this is the case, have you thought about squaring off the front portion of the case, so that the rear portion is circular and the front is rectangular? I'm primarily asking because that could again eliminate extra material that's not needed on the front, and give the front piece a slightly sleeker look (IMO, anyways). Great job though, that lens looks very professional and polished.
There are 10 types of people: those who understand binary, and those who don't.
HogPilot is offline
post #12 of 23 Old 05-03-2010, 08:05 AM - Thread Starter
dr.nop's Avatar
this may not be the last version ,I may develop focusring for adjusting astigmatism in future and this design is so luxurious than square , I think
dr.nop is offline
post #13 of 23 Old 05-03-2010, 03:49 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
So how large is this screen?
Mark Techer
CAVX is offline
post #14 of 23 Old 05-04-2010, 05:31 AM - Thread Starter
dr.nop's Avatar
my screen is stewart cine w 115" throw ratio 2.0 pj jvc rs 15
dr.nop is offline
post #15 of 23 Old 05-04-2010, 05:41 AM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
Is the 115" a diagonal or with?
Mark Techer
CAVX is offline
post #16 of 23 Old 05-04-2010, 05:57 PM - Thread Starter
dr.nop's Avatar
diagonal
dr.nop is offline
post #17 of 23 Old 05-05-2010, 03:55 AM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
diagonal
So about 105" wide and why the depth works. I'd be interested in feedback for longer throws (same TR).
Mark Techer
CAVX is offline
post #18 of 23 Old 05-11-2010, 08:56 PM - Thread Starter
dr.nop's Avatar
screen shot from avata
dr.nop is offline
post #19 of 23 Old 05-11-2010, 10:51 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
Where
Mark Techer
CAVX is offline
post #20 of 23 Old 07-13-2010, 08:42 PM
greg_mitch's Avatar
greg_mitch is offline
post #21 of 23 Old 07-14-2010, 06:24 AM - Thread Starter
dr.nop's Avatar
thank you very much
dr.nop is offline
post #22 of 23 Old 07-14-2010, 06:19 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
thank you very much
dr.nop, how did you go at longer throws?
Mark Techer
CAVX is offline
post #23 of 23 Old 07-15-2010, 05:31 AM - Thread Starter
dr.nop's Avatar
right now ,i use 2.0 TR if longer TR spacer for posterior element may need like yours
dr.nop is offline
Reply DIY Constant Height
