DIY Prism Housing schematics... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-10-2010, 03:15 PM - Thread Starter
seedubxj's Avatar
I know I have seen a build diagram on this site in the past, but cannot locate it now.
I will be using 4x6 trophy prisms.
Can someone link me to a blueprint for the housing? Thanks in advance!
seedubxj is offline
post #2 of 5 Old 05-11-2010, 12:32 AM
CAVX's Avatar
Quoted: 211 Post(s)
Liked: 113
I couldn't locate the thread either, so maybe its been deleted.
Alignment is quite easy, you need the apex of the rear prism to face towards the projector and the base of the front prism to face towards the screen. The angles of "displacement" will depend on the angles of the prisms used where the thicker the prisms, the less angle needed. I would attach an image, however all of my images have my logo on them and I am not permitted to display my logo as that is considered "advertising".
Your enclosure need only be wide enough to house the prisms once set at their angles (unless you intend to include a bi-pass). You may also need to have one side shorter then the other (exposed angled side of the front prism) to prevent vignetting. I'd suggest taking a look on the 235 screen thread (sticky in the main forum) for photos of the DIY prism lenses members have made for ideas.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #3 of 5 Old 05-11-2010, 09:44 AM
JDLIVE's Avatar
Quoted: 98 Post(s)
Liked: 56
Send a message via Yahoo to JDLIVE
Maybe this will help?
JDLIVE is offline
post #4 of 5 Old 05-11-2010, 11:48 AM - Thread Starter
seedubxj's Avatar
Thanks JD. I have already found that page, but I was looking for more of a specific diagram, measurements included.
seedubxj is offline
post #5 of 5 Old 05-11-2010, 04:34 PM
CAVX's Avatar
Quoted: 211 Post(s)
Liked: 113
1. You need to work this out on a table so remove the projector from the ceiling mount if it is already installed there.
2. Start on the table with placing a piece of paper in front of the projector.
3. Place the prisms on the paper in the light path.
4. Displace the prisms so you achieve anamorphic stretch. You will need a 2.37:1 for this or you can use a 16:9 screen and 4 x 3 on the projector.
5. Trace around the prisms with a pencil.
6. Take the paper to the workshop to make your enclosure.
Mark Techer
CAVX is offline
Reply DIY Constant Height
