Tried searching but couldn't find the info I wanted.
My question is this. I will be building a 2.35:1 Cinemascope Fixed screen with Da-Lite High Power screen material with Diy side masking. I'll be using it with an AE4000 or 3D AE series successor.
Does the Programmable 12v trigger feature mean the PJ can be set to send a trigger pulse for aspect ratio changes when it does its CIH zooming. If so I'll probably make a simpler system that just masks to 16:9 and 2.35:1, ie. fully open or fully closed and put up with the resultant overscan on 1.85:1 and 2.40:1
If however I can't totally automate the opening or closing of the masking I'll probably come up with a remote controlled variable system instead.
