Side Masking: Independant Control of Masks? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 01-01-2011, 01:21 AM - Thread Starter
Gregory's Avatar
This question pertains to a CIH set-up using zoom and shift strategy (not A-lens).
Is it ever necessary to have independent control over the side masks vs one mask synchronized to the other? Is there a condition where I would want to move one mask slightly more or less than the other? If so, I would imagine that this could also be accomplished with the projector's shift controls.
Thanks and Happy New Year,
Greg
Gregory is offline
post #2 of 15 Old 01-05-2011, 05:56 PM - Thread Starter
Gregory's Avatar
Maybe I should state the question a different way:
Those of you who make your own masking systems, do you design it for individual control over each of the vertical masks or just allow both masks to move together?
The Masquerade has both modes: you can move each mask independently or move them as a group, shifting both left or both right.
I was just wondering how necessary it is to have individual control, as you need an additional motor and control circuitry. Have you ever come across a situation where it would be helpful, off center movie, for example?
Greg
Gregory is offline
post #3 of 15 Old 01-05-2011, 10:45 PM
Somis's Avatar
Gregory-
I've designed both a single and a dual-motor system. I would say that the dual-motor approach is easier to implement from a mechanical standpoint. The drawback is of course having to incorporate an extra motor and controller that is more sophisticated.
Independent control is not neccesarily an advantage, but you get it for free.
Don
Somis is offline
post #4 of 15 Old 01-06-2011, 10:08 AM
TSHA222's Avatar
Liked: 71
I am planning a motorized masking system and will have them independently controlled. Just my preference. I just think it will be simpler to operate, so if, like a previous poster mentioned, you have a rare title that is a bit off-center, you're covered. I'll just have to have left and right buttons on my Crestron.
TSHA222 is offline
post #5 of 15 Old 01-06-2011, 07:23 PM - Thread Starter
Gregory's Avatar
Thanks for the comments.
I'll probably go for dual motors because as Don suggested, it will be mechanically less of a headache to implement.
Thanks again,
Greg
Gregory is offline
post #6 of 15 Old 01-06-2011, 11:07 PM
Knackers's Avatar
I don't think the mechanics are any easier with dual motors, in fact, the contrary. My commercial system uses dual motors, but as Don said, you require a far more complex controller. And depending on how you intend on setting position stops (mechanical or electronic) also introduces another challenge. Dual motors require synchronisation for movement, but at the same time require independance to set offset positions.
For a DIY solution, I'd be going for a single motor using pulleys and belts - easy to synchronise, less complex controller, single stop, less components so cheaper etc, etc...
Cheers,
Chris
Knackers is offline
post #7 of 15 Old 01-07-2011, 08:23 AM
taffman's Avatar
My DIY masking system uses a single motor for the left/right masks, and a single motor for the vertical up/down masking. That way I can exactly mask any format of film. Single motor left/right masking is much easier to implement than independent left/right masking. I have had no problems with pictures not being centered on the screen, so I see no need at all for independent control of left and right masking panels.
taffman is offline
post #8 of 15 Old 01-08-2011, 10:23 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
A few years ago, I did a mock up of a concept system known as "Gull Wing" which was essentially two hinged doors to cover the side pillars of unused screen. It worked well and I have been thinking about doing an AT version. Just wondering if anyone else did anything similar and if it would be possible to automate it?
Mark Techer
I love my Constant Image Height system!
CAVX is online now
post #9 of 15 Old 01-09-2011, 12:45 PM
Somis's Avatar
Synchronization of a dual-motor system is difficult. I would say that it is not necessary, but it loses that WOW factor. For that reason, I prefer the single-motor approach. There's nothing cooler than watching both masks move in perfect unison.
BUT, this means the addition of belts and cables, that make it more complicated mechanically. Plus, you need to add torsion springs inside the rollers.
So, it is a trade-off. If you're not bothered by the fact that each mask is not synchronized with the other, than the dual-motor system is the easiest to implement.
Don
Somis is offline
post #10 of 15 Old 01-09-2011, 06:29 PM - Thread Starter
Gregory's Avatar
What I had in mind was to have both functionalities. Both masks would move in unison, but I would also have the ability to jog each of the masks left or right independently. This would require a dual motor system.
If the jog capability is not required then a single motor system with a cable would be sufficient.
Greg
Gregory is offline
post #11 of 15 Old 01-09-2011, 09:20 PM
taffman's Avatar
Wow, that's a very unique and innovative approach Mark. I have never seen such a system deployed but I see no reason it would not work. Only drawback that I can see is that you would lose the WOW factor of having the masks slowly moving out to reveal that great CinemaScope picture- something that always blows away my audience!
taffman is offline
post #12 of 15 Old 01-09-2011, 10:00 PM
Somis's Avatar
Gregory-
I'm still trying to come up with a need to have both masks move independently. The dual-motor system allows this, but it is just because the left and right mechanisms are not connected to each other.
I would be surprised if you can find two motors that run at exactly the same speed. With encoders on both motors, you can control position and speed , but that's where you need more complex electronics.
You can jog the masks in a single-motor system. If you have presets, then the jog function is only needed for initial setup.
Don
Somis is offline
post #13 of 15 Old 01-10-2011, 05:22 AM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
Thanks Taffman The manual prototype version I made in 2006 used hinged MDF panels and was a bit heavy. When closed, the screen looked like a regular 16:9, then when I opened the masks, suddenly there was the wow that only scope can bring.
Mark Techer
CAVX is online now
post #14 of 15 Old 01-11-2011, 02:54 AM
Knackers's Avatar
Originally Posted by Somis View Post
Gregory-
Don
The main reason I believe independant control is valuable is mainly in the initial setup stage. Very rarely does anyone get the projector in exactly the right position, so having independant control allows you to "fine tune" the setup. Granted, once it's set for all masking positions, you should never have to touch it again, so the use is limited, but still worthwhile IMHO.
Also, I've been able to achieve dual motor synchronisation, but by doing exactly what you've said - using dual motors each with high resolution encoders.
Cheers,
Chris
Knackers is offline
post #15 of 15 Old 01-11-2011, 07:07 PM - Thread Starter
Gregory's Avatar
Thanks for the advice, Chris.
I probably will go with the dual motor system with the jog controls. This will be with a motorized screen, so I will have limited room for any additional mechanical apparatus (cabling, tensioners, pulleys, etc.).
Thanks to everyone for the advice and comments. It is greatly appreciated.
Greg
Gregory is offline
Reply DIY Constant Height
