diy buying guide - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-04-2011, 07:46 PM - Thread Starter
wildchild22's Avatar
Quoted: 29 Post(s)
What is the best diy prisms to buy? I have been reading lately about diy prisms and would like to build some and would like to know if the surplushed are still the best diy prisms to buy?
http://www.surplusshed.com/pages/item/l9113d.html
Also where is the best and easiest plans to build by?
wildchild22 is offline
post #2 of 9 Old 07-05-2011, 01:22 AM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
They are optically coated, but are physically small and not corrected for CA or astigmatism.
Mark Techer
I love my Constant Image Height system!
CAVX is online now
post #3 of 9 Old 07-05-2011, 08:51 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
They are small as CAVX points out as well as the the other issues he mentions. If that's not a deal breaker then I would say yes they are probably one of the better solutions for DIY. Throw distance will matter with these prisms, my projector is at about 14' from the screen and this allows for about 1/3 of my zoom range to be usable with the prisms in place.
As far as a case, you can find various DIY examples out there if you search. The thread here has what I did which has worked out nicely with easy latch access. Final product on page 7. Also at the beginning of the thread I linked some dimensional drawings that may aid you in making your own case. If I recall correctly I had to shrink the case/lens template on a copier by 10% to make it the right size.
Good luck
oman321 is offline
post #4 of 9 Old 07-05-2011, 03:53 PM - Thread Starter
Quoted: 29 Post(s)
Thank you so much. I have no projector just getting started. I am going to build the prisms then decide on a projector.
post #5 of 9 Old 07-06-2011, 05:41 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Once you build the lens you are going to want a projector fast!! Maybe someone you know has a projector to test out on.
Just note when you are ready to test (in case you do it table top) that the lens needs a little downward tilt to aid in squaring up the picture and eliminate what looks like keystone effect.
oman321 is offline
post #6 of 9 Old 07-08-2011, 03:44 PM - Thread Starter
Quoted: 29 Post(s)
Will the vivtek qumi work with the surplus shed prisms?
http://www.avsforum.com/avs-vb/showthread.php?t=1304775
post #7 of 9 Old 07-08-2011, 10:11 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
If the throw is long enough.
Mark Techer
CAVX is online now
post #8 of 9 Old 07-09-2011, 06:55 AM
230-SEAN's Avatar
Would it be bright enough?
-Sean
230-SEAN is offline
post #9 of 9 Old 07-10-2011, 10:12 AM - Thread Starter
Quoted: 29 Post(s)
I do not care about brightness. I have a 100% black room not light. I only want around 10 to a max of 12 ft lamberts of light or it hurts my eyes.
I think the qumi should fit the bill perfectly.
Reply DIY Constant Height
