Setuping Up Prisms/Distance - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-16-2011, 04:15 PM - Thread Starter
ojuicy's Avatar
I was just curious how most of u you guys setup your prisms to figure out the distance and angles before you permantly mounted them when using a ceiling mounted projector? I have tried stacking a number of boxes up and placing the prisms on top of those boxes but the boxes aren't perfectly level causing some issues.
Would I be able to take down the projector and put it on a table at same distances from the screen and then setup the prisms or will the math/angle be slightly different?
As always you guys are a great help, and thanks in advanced.
ojuicy is offline
post #2 of 5 Old 09-16-2011, 06:44 PM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
A table top set up (directly beneath your ceiling setup) will be the easiest to align the prisms. If you change the TR, your final angles will also change.
Mark Techer
I love my Constant Image Height system!
CAVX is online now
post #3 of 5 Old 09-16-2011, 08:11 PM
230-SEAN's Avatar
Yeah, it is a PITA.
-Sean
230-SEAN is offline
post #4 of 5 Old 09-17-2011, 10:39 AM - Thread Starter
ojuicy's Avatar
is the distance between the two prisms always the same? I was planning on mounting them with pivoting points, is the distance between these two pivot points a constant? regardless of the throw ratio ?
ojuicy is offline
post #5 of 5 Old 09-17-2011, 05:42 PM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
The prisms can physically touch if you want. Prisms do not have a focal length so the spacing can be what ever it needs to be so as not to vignette.
Mark Techer
CAVX is online now
Reply DIY Constant Height
