DIY Scope Masking - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #31 of 50 Old 09-19-2012, 04:43 PM - Thread Starter
warrenP's Avatar
Liked: 60
Originally Posted by Brian Hampton View Post
I bought some nice black velvet and just hung it with Velcro to see how it would work
I was amazed it was so effective. I'll have to redesign it with some foam boards at the least but I've never had a 2:40 screen and that's what it looked like and I felt like I was at the movies.
It is awesome! Welcome to the club!
Every man dies. Not every man really lives.
warrenP is offline
post #32 of 50 Old 10-21-2012, 10:24 PM
MattGuyOR's Avatar
I can't get the video to work. I have a 120" 2.37:1 screen and anxious to learn how to add side masking. I'm extremely un-handy, too. Haha.
MattGuyOR is offline
post #33 of 50 Old 12-07-2012, 02:18 PM - Thread Starter
warrenP's Avatar
Liked: 60
Link fixed for the video. Should be fine to play there in the thread now. Thanks!
warrenP is offline
post #34 of 50 Old 12-08-2012, 09:09 AM
Brian Hampton's Avatar
Quoted: 582 Post(s)
Liked: 311
I finished mine. I bought six rare earth magnets for $20 but could never get them working for me.
In the end, I have L brackets (upside down) that hang the top mask on. I attach the bottom using C hooks on both the screen wall and the mask panel.
So, its a little job to setup but well worth it.
I was sad to have to watch the Dark Knight Rises without the masks due to the variable aspect ratio ( the Bane of the CIH setup.)
Brian Hampton is offline
post #35 of 50 Old 12-08-2012, 04:38 PM
astrogeeker's Avatar
yea had the same experience last night.. set up my mask.. popped in dark knight... ahhh...foiled again! i hope this isn't a sign of things to come with future movies..
astrogeeker is offline
post #36 of 50 Old 12-15-2012, 03:32 PM
windrockwater's Avatar
Thanks alot for posting this. Your video really shows it. I monkeyed together my own similar system before I saw your post. I am using two eye-hooks screwed into the ends of the mask panels and then there is two screws sticking out of my soffit that I hang the panels on. Not as pretty as yours. So I am going to try the magnet idea. I am using rigid pink insulation for my panels and wrap them in blackout fabric. I tried sticky metallis duct tape but thats not doing it. What type of tape did you use with the fabric?
Epson 6020UB Projector
Dalite Contour HighPower Manual Pull Down
Denon AVR3311CI
Sony PS3
B&W CDM-7NT Speakers
windrockwater is offline
post #37 of 50 Old 03-06-2013, 08:50 PM
RLBURNSIDE's Avatar
Quoted: 1968 Post(s)
Liked: 1524
Super cool masking technique! I've been thinking about doing something very cheap / homemade similar to this, but I may even just copy this entirely. I used to live in a big loft but am now in a much smaller condo, and think my new projector's 16:9 mode is just too useful for games and tv shows to try constant height setup, I think constant width as you have done is cheaper since 16:9 screens are probably cheaper (are they?). Also, vertical contraction anamorphic lenses are easier to do with less side effects than horizontal expansion, so I may make myself a DIY lens setup as well. I think it's just simpler to move my projector back a bit, because I'll be at the width limit of my living room anyways and can't really use 1.33x times that, so squeezing it down vertically + this type of 2:35:1 masking system could be the el-cheapo way to get very good brightness and image quality.
thanks!
RLBURNSIDE is offline
post #38 of 50 Old 05-06-2013, 09:07 PM - Thread Starter
warrenP's Avatar
Liked: 60
thanks!
Sorry for the delay, my Subscription setting wasn't right, so I didn't see your reply until now...
Often the 16:9 are cheaper, simply due to volume of production. Yep, the vertical masking is usually easier to do - just as you stated. If you do copy this (and I'm happy if you do!) please post some pics so we can see what you create. smile.gif
warrenP is offline
post #39 of 50 Old 05-06-2013, 09:10 PM - Thread Starter
warrenP's Avatar
Liked: 60
I just used standard fabric tape from Joanns. I moved this last Summer, so I don't know how long that exact setup will last. It was a test design. On something more permanent, I would use fabric adhesive.
warrenP is offline
post #40 of 50 Old 05-20-2013, 10:35 PM
Spirit2's Avatar
Awesome work!
My only concern with incorporating such a system is getting shadows thrown from the bottom of the top panel onto the screen as my projector is ceiling mounted more or less at the height of the top of the screen.
Have you ever had any trouble with shadows?
Cheers!
[edit]
I suppose if I set it up right, I could have the top panel only *just* out from the level of the screen, and taper the lower edge if necessary.
Spirit2 is offline
post #41 of 50 Old 11-20-2013, 12:08 PM
cardoski's Avatar
Quoted: 1373 Post(s)
Liked: 1416
Ok I think I know the answer, but I want to be sure, how did you determine how big the masking would be? I have a 115in 16X9 fixed screed. And am about to get a new JVC PJ that can do cinescope. So I want to make the masking before I get the new PJ and am not sure how big the black bars will be. Thanks for any help.
It's always in the last place you look.
cardoski is online now
post #42 of 50 Old 11-21-2013, 07:25 AM - Thread Starter
warrenP's Avatar
Liked: 60
Since this is a top-down masking system, the width is the constant. A 115 inch 16:9 screen has dimensions (assuming that 115 inch is the diagonal measurement) of 57" (tall) and 100" wide. A scope screen (using 2.39:1 as the ratio) has dimensions of 42" (tall) and the same 100" wide. So you would have 15" total to mask, 7.5" for the top and 7.5" for the bottom.
warrenP is offline
post #43 of 50 Old 11-21-2013, 07:46 AM
cardoski's Avatar
Liked: 1416
Thanks so much, I was off by an inch, big help. Love the masking you did very clever.
post #44 of 50 Old 07-27-2014, 06:08 PM
Ebase131's Avatar
Quoted: 38 Post(s)
Nice, glad someone was able to pull and modify this idea some. So much fun to have the masks, isn't it?
I think sometimes we DIY guys tend to over-engineer (ok, pretty much all the time....) everything, and these simple and effective ideas are important. I use my masks all the time. I know lots of guys who built masks and don't take the time, they don't want to mess with getting the pressure fit right, or getting the velcro right, etc... with this idea, it is like 2-3 seconds to open and close them.
I hope some other guys take and tweak this idea even further. Ideas can always be improved, and when I get to making my next one I want to swipe those better ideas!
Really cool idea and can solve some space issues and storage issues of these panels, and as you mention it's relatively simple to achieve.
My main concern would be if there is any creasing apparent when unfolding the masks into position for the smaller screen. Are there any noticeable folds? I would hope the material being black and light absorbing and the lack of lighting in a HT would provide for enough darkness that it would be dang near impossible to see without being anal and inspecting from up close...
Ebase131 is offline
post #45 of 50 Old 12-05-2014, 04:00 PM
Daniel Chaves's Avatar
Quoted: 414 Post(s)
Liked: 306
Thanks for this write up, Im going to making something similar, after I get done making the surround, I have a painted on screen so I have to modify this idea a bit but yeah I will post pictures if your interested when I am done.
Projector: BenQ w1500 + ES Sable 135" Screen AVR: Onkyo TX-NR646 ATMOS/DTSX + Darbee 5000s
Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), Monitor40 Series II (RL/RR),
Onkyo THX Bookshelf Speakers (Ceiling L/R), (2) JL Audio 12" Subs + (2) Dayton 15" Subs + (2) ButtKicker LFE
Arrangement: 5.1.2 Source: OPPO UDP-203 4k Bluray Player, Roku 4, HTPC, Nexus Player
Daniel Chaves is online now
post #46 of 50 Old 07-14-2015, 06:09 PM
tcramer's Avatar
Quoted: 280 Post(s)
Liked: 126
Sorry to dig up your old thread but I do have a question. I know you are using magnets on the panels, but where exactly and how are the corresponding magnets connected to the screen/frame?
I made some panels and wanted to use magnets, but had to use velcro since the frame is aluminum and therefore not magnetic.
Btw, awesome panels.
JVC DLA-RS600, 110" Stewart Cima Neve, Oppo UDP-203, TiVo Bolt, Denon X4300H
Dual Rythmik FV15HP, Energy Veritas Fronts and Surrounds, 4x RSL C34E for Atmos
tcramer is offline
post #47 of 50 Old 10-11-2015, 09:52 PM
Quoted: 12 Post(s)
Liked: 0
interesting. thank you for the idea
maciawa is offline
post #48 of 50 Old 04-18-2016, 07:01 AM
Quoted: 14 Post(s)
Liked: 1
I would like to make using magnet. Is there any issue with magnet and speaker or subwoofer?
Do you have any picture or any more detail about velcro method?
Bilimoria is offline
post #49 of 50 Old 05-09-2016, 06:34 AM
Quoted: 34 Post(s)
Liked: 3
Question
Hey bud, I'm not sure I understand how this works but keen to give it a go as currently about to build my first screen.
So does the masking panel tuck up behind the frame or does the top and bottom of the frame essentially slide down/up to mask the screen?
The bit I'm not really understanding is how the extra velvet to extend the border is hidden when in the 16:9 position.
farr3ll is offline
post #50 of 50 Old 05-13-2016, 09:53 AM
JGM
JGM's Avatar
Quoted: 117 Post(s)
Liked: 80
Has anyone done something similar for a drop-down (tab-tensioned) screen?
JGM is offline
Reply DIY Constant Height
