DIY Lens angle - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-12-2012, 07:59 PM - Thread Starter
vagpwner's Avatar
Hello,
ive decided to go with a conventional design but how should i know what
angle i have to place the prisms at to get the proper image?
vagpwner is offline
post #2 of 5 Old 02-13-2012, 02:46 AM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
Originally Posted by vagpwner View Post
Hello,
There is no actual fast rule for this as the exact angle for the prism rotation is based on the angles of the prism themselves and the throw ratio of the set up. Example, if you set up a lens using prisms for a short throw, the decide to increase the throw ratio, you will need further rotation for the longer longer throw. This happens mainly because of grid distortion.
The best you can do is to make a 2.37:1 screen, then project your 16:9 image (top to bottom is framed, left to right is centered), then add the prisms and rotate until you get the edges aligned.
Mark Techer
I love my Constant Image Height system!
CAVX is online now
post #3 of 5 Old 02-16-2012, 09:54 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
oman321 is offline
post #4 of 5 Old 04-09-2012, 07:56 AM
studlygoorite's Avatar
Quoted: 104 Post(s)
Liked: 44
If I may, my friend just put together his DIY lens and if his 16.9 pic is set correctly and he slides the lens in front, his 2.4 pic is now two inches below. Does he have his prism angles incorrect or is it just as simple as tilting the lens to fix it?
He said he lined up the 16.9 pic perfect and worked off that to set his prism angles, but maybe when solidifying the prisms they got skewed?
John
Anthem AVM 60, Paradigm Sub 2, Paradigm S8s with C5, Anthem Statement M1 Amps, 174" Curved AT Scope Screen, Epson Pro Cinema LS10000 Laser 3D Projector, Samsung 4K Blu-ray Player, Oculus Rift VR, Xbox One, PS4, Clark Synthesis Transducer For Chair
studlygoorite is offline
post #5 of 5 Old 04-13-2012, 06:49 AM
Quoted: 104 Post(s)
Liked: 44
John
My friend flipped the lens unside down and all aligns perfectly.
Reply DIY Constant Height
