French prism article - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-03-2012, 05:58 AM - Thread Starter
myky's Avatar
Hello all!
Few years back I made an article about the "DIY anamorphic lens". It was all in Finnish so it would not have any use for you. Now I founded again my first drafts so I decided to translate it to english and put it here. I cannot post the the final version of the document, but the basic idea is the same.
It made the translation pretty quickly so there will be spelling mistakes but the major idea is quite clear.
The document is about 2,5MB so I had to make to remove few pictures and spilt the document.
Again sorry about the long time. Even the topic for the french prisms was closed
Hopefully somebody will read it. Please feel free to comment.
Mika Myrberg
DIY anamorpic lens part 1.doc 158k . file
DIY anamorpic lens part 2.doc 416.5k . file
myky is offline
post #2 of 8 Old 04-03-2012, 02:21 PM
wildchild22's Avatar
Quoted: 29 Post(s)
thanks for this I am going to be building mine this week!!!
Are you still using yours?
wildchild22 is offline
post #3 of 8 Old 04-03-2012, 11:05 PM - Thread Starter
myky's Avatar
I would if my new house would allow it. There is just not enough space where I could use it. But before I moved I used it 100% of the time (except when I watched TDK).
myky is offline
post #4 of 8 Old 04-04-2012, 04:07 AM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
I think TDK is quite acceptable in Scope because all of the IMAX scenes were framed to match with the rest of the Scope film.
These prisms are small, but do have an optic surface finish and optic coating so should (whilst not perfect) give better results than the "trophies" used in many DIY anamorphic adapters.
CA will always be a problem because of the fact that these prisms are made from just one type of glass.
Astigmatism correction requires either special additional lenses or curved surfaces ground into the prism. If one was to take the time and effort to do that, one might just consider cylindrical lenses a better alternative.
Grid Distortion will always be worse with this type of design.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #5 of 8 Old 04-08-2012, 06:58 PM
b_123's Avatar
What's the concern with having small sized prisms? Will we lose some light?
Can CA be reduced if one of the prisms were made of another material, or would we need to form two achromatic doublets?
b_123 is offline
post #6 of 8 Old 04-08-2012, 08:39 PM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
Vignetting is the main concern.
Achromatic Doublets are the minimum needed for CA correction.
Mark Techer
CAVX is offline
post #7 of 8 Old 05-04-2012, 08:23 AM
Efalegalo's Avatar
Quoted: 23 Post(s)
Shoot! - I'm afraid I may have ordered the wrong crystal wedges for my DIY lens. Specifically, I ordered the "J24" - 4"x6" crystal wedges from Massilon Plaque - cost about a $100 shipped. Should I have ordered the ones from SurpluShed instead? I placed an order for the Massilon crystal wedges yesterday so I may still have time to cancel.
Any thoughts anyone?
Dhar
Efalegalo is online now
post #8 of 8 Old 05-05-2012, 04:20 AM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
Dhar
As I mentioned, you should get better results from the SS (French) prisms because they have both a proper optical finish as well as optic coatings.
Mark Techer
CAVX is offline
Reply DIY Constant Height
