Pivot point on Prisms - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-08-2012, 10:43 AM - Thread Starter
ojuicy's Avatar
I have purchased two prisms and am going to mount them to a metal plate and then mount them to my ceiling mounted projector. My question is what should I use as the center pivot point to mount the prisms? Should i use the incenter, circumcenter or the centroid of the triangle? thanks for your help.
ojuicy is offline
Reply DIY Constant Height
