AT curved scope build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 01-04-2014, 09:11 AM - Thread Starter
armstrr's Avatar
OK...I am early in the process and have been encouraged to start the thread now...so perhaps this will be of use/enjoyment for others.
I'll give some background.
Current theater was completed about 6 years ago. It is approx13' wide by16 and change deep.
I recently took down a marquee 9500lc CRT projector that served me well for those years and decided the market in digital projectors was ready for me wink.gif
A few years ago I grabbed a b stock panamorph uh 480...and have always been looking forward to a day where I could use it for
More in a bit...
mtbdudex likes this.
armstrr is offline
post #2 of 18 Old 01-07-2014, 06:14 AM
roxiedog13's Avatar
Quoted: 593 Post(s)
Liked: 205
More in a bit...
I may be building the same. I'm interested in a curved masking system for a 130" diagonal 2.35 that I can mask for 16:9 and 4:3 too. My objective would be to have the masking system to completely close . I may even consider
a flat screen and multipul masking formats as well.
I have a Sony 600ES and also have the UH480 btw.
Dedicated Theater: Sony VPL VW500ES, Panamorph DC1 Anamorphic Lens, Draper TecVision XT1800X Screen, 2.40:1 132" diagonal curved 36FT radius, Denon X5200 , 7.2.4 Atmos, Paradigm Monitor 11 fronts, Monitor 3 Center, Monitor V7 Rear, SA-ADP In-wall Surround, Niles DS-7 In-Ceiling, Subwoofers: (4000 watts peak) Klipsch RW-12 + SVS PC13-Ultra
roxiedog13 is offline
post #3 of 18 Old 01-07-2014, 07:44 AM - Thread Starter
armstrr's Avatar
I had some falcon screen AT material delivered and have begun the the build. I purchased 12' 2x8 and 2x4 lumber. I clamped the lumber together and let it sit for a week in the hope the lumber would acclimatize to the humidity and remain fairly stable.
Based on Aussiebob's calculator (props to him!) I came up with a 35.8' radius. My prefference would be to set up a trammel and physically mark the curve...and were it summer, that's how it would have been done. given this weeks temps of -40 deg C (with wind chill)...no screen is worth that, so i embarked on mathematically calculating the depth of the curve from the chord. A lot of googling, some help from some forum members and a couple friends (thanks Tosh's!!!), I got a formula and was able to build a chart, and then check it by graphing it. it worked! Even if you have never used the metric system, it may be worth trying it since working to the nearest mm is easier than calculating fractions of inches...and AB's excel spreadsheet allows you to input both metric and imperial units, so you can go between them at your convienience.
I printed depths for 5cm and 1cm increments from the center point...just in case. I ended up finding the 5cm increments enough. I then cut a strip of wood approx 1/4" by 11/4" x 11' and drove screws about every 20 cm used the wood to mark the curve...see pics below.
my plan is to cut out the curve and then attach a piece of lumber vertically to the curve that will act as the masking and and serve to stiffen the structure and lessen the chance to flex. I plan to rip the 2x4 on a tablesaw to the correct dimentions...likely 1/2" thick. the masking can only be 2 2/4" wide as that will yeild just enough room to slide my subs under the screen frame as i only have 82" height due to duct work, and the subs (laying on their sides...) are 22 1/4" high.
i purchased o-rings from amazon as well as a grommet kit and refils. My plan is to fold the falcon screen material over duct tape or a fabric stifening tape...(not sure what its called...and grommet through the tape and doubled over material. screws or bolts placed around the edge will act as anchor points for the o rings to tension the screen. this method of screen building and tensioning has been borrowed from some other screen builds.
armstrr is offline
post #4 of 18 Old 01-07-2014, 08:18 AM - Thread Starter
armstrr's Avatar
armstrr is offline
post #5 of 18 Old 01-08-2014, 05:18 AM
Tedd's Avatar
Quoted: 701 Post(s)
Liked: 263
usb port digital movie poster light box project
http://www.avsforum.com/forum/32-the...ay-got-me.html
Tedd is offline
post #6 of 18 Old 01-08-2014, 06:07 AM - Thread Starter
armstrr's Avatar
Originally Posted by Tedd View Post
but this time I'm using math!
armstrr is offline
post #7 of 18 Old 01-11-2014, 01:33 PM - Thread Starter
armstrr's Avatar
armstrr is offline
post #8 of 18 Old 02-26-2014, 03:53 PM - Thread Starter
armstrr's Avatar
armstrr is offline
post #9 of 18 Old 02-27-2014, 11:36 PM
blastermaster's Avatar
Quoted: 378 Post(s)
Liked: 455
Looks great, man. Glad to see a fellow Canuck doing a curved screen. I built one myself and it's the bees knees around here. I initially used spandex but I ended up switching it out and went with Seymour Centerstage XD material and it's been fantastic. I'm looking forward to seeing how it all turns out for you. Best of luck.
Video: Optoma HD3300, Panamorph UH480, Darbee Darblet, Samsung BD D6700 Blu Ray player, DIY Seymour Centerstage XD 138" Curved Screen
LCR - Tannoy DC12i, Sides - Tannoy IW63, Rears - Tannoy IW62tdc, Ceilings - Tannoy CMS 603DC (TF), Tannoy CMS 601DC (TR), Micro Marty/Full Marty DIY subs
Amplification: Emotiva XPA-3, Emotiva XPA-2, Outlaw Audio 7700, Inuke 6000DSP
Receiver: Anthem MRX 720
blastermaster is online now
post #10 of 18 Old 02-28-2014, 09:31 PM - Thread Starter
armstrr's Avatar
Painted
Installed turnbuckle and eyebolts to bring it back dead straight since the main horizontal frame bowed in toward the cut
Drilled and glued in neodymium magnuts to hold masking panels
armstrr is offline
post #11 of 18 Old 03-01-2014, 11:09 AM - Thread Starter
armstrr's Avatar
A little Royalty 3 velvet (not to be confused with Royalty 1 or 2!)
armstrr is offline
post #12 of 18 Old 03-03-2014, 05:05 PM - Thread Starter
armstrr's Avatar
Final size: 127 x 53- (137 ³/⁴" diagonal)
armstrr is offline
post #13 of 18 Old 03-20-2014, 07:33 PM - Thread Starter
armstrr's Avatar
armstrr is offline
post #14 of 18 Old 03-20-2014, 07:34 PM - Thread Starter
armstrr's Avatar
The money shot... (Quick and dirty alignment...no calibration)
armstrr is offline
post #15 of 18 Old 03-31-2014, 05:13 PM - Thread Starter
armstrr's Avatar
I Started the masking panels. Simple 1/4" hardboard with magnets mounted to match the screen. Cut outs made to save weight. Corners rounded to better accept the velvet that will be glued on.
The magnets are spaced such that I can slide them over for 1.85 movies if I choose... The bit I used gave a very snug fit, so I drilled through flushed the magnets up and then mixed up epoxy and filled in the backside.
The clamps are holding a 3/8" thick strip of pine to the inside edge. This will keep the panels from bowing and take up the gap that would otherwise be about a 1/2"
armstrr is offline
post #16 of 18 Old 03-31-2014, 05:51 PM
mtbdudex's Avatar
Quoted: 77 Post(s)
Liked: 593
Awesome job, hopefully others will see DIY can be fun, save $, and satisfaction.
mtbdudex is offline
post #17 of 18 Old 03-31-2014, 07:25 PM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 75 Post(s)
Liked: 117
Great Work looks awseome can't wait to see some final pics.
snickers1 is offline
post #18 of 18 Old 04-07-2014, 08:29 AM - Thread Starter
armstrr's Avatar
Anyone who has debated the merits of black velvet...it may be the biggest improvement 200 bucks can bring to a projector install. I built some light framing by ripping some 3/4" ply into 1 3/4" strips. The Kreg jig may be the best thing since sliced bread for building.these...each panel took about 20min to build. Friction fit and a few strategicly placed magnets hold everything in check Joannes 50% off coupon helped with the 23 yards I ordered...approx 3000 staples later...
armstrr is offline
Reply DIY Constant Height
taboola here
