Diy CIH motorized masking with somfy LT30's - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By MALIX
post #1 of 7 Old 03-25-2014, 10:55 PM - Thread Starter
MALIX's Avatar
Liked: 33
Well after lots of reading and thinking about how to do my motorized masking I have cobbled together pieces from several of the threads available on AVS and begun my build.
Much thanks to the following posts for inspiration.
http://www.avsforum.com/t/941076/4-way-acoustically-transparent-masking
http://www.avsforum.com/t/1251657/ciw-electronic-masking-diy-and-very-easy
http://www.avsforum.com/t/1150424/my-implementation-of-scottj0007s-cih-masking
Especially Moggies
http://www.avsforum.com/t/1295320/diy-curved-at-screen-with-somfy-based-automated-masking
Thanks, guys.
Ok so I've started by ordering parts from http://www.avoutlet.com/.
2- AVO 12VD100W - 12VDC 1A White Wall Plug Power Supply w/
Terminated Power Supply: Terminated to 12'
2- Rollease RTEA4T12-6 Roller Shade Tubes w/ Tape - 1.5" x 6 Foot
2- Rollease SLAMLT30 Skyline to Somfy LT30 Bracket Adapter
4- Rollease SLB660 Skyline Shade Brackets
2- Rollease SLPEHD53 Skyline Heavy Duty End Plug for 1.5" Tubes
2- Somfy 1000679 LT30 IR 12VDC Roller Shade Motor with
Options: Crown and Drive Options: 9013488 Rollease 1.5" Tube (+$7.32) , IR Sensor Color: Black (+$11.00)
and 1-Somfy 1870132 LT30 - IR8 - Eight Channel IR Remote Control
Total cost: about $370
Also purchased t track, Aluminum flat stock for the masking ends..sy fabrics triple plush velvet and misc screws etc..
I did lots of research for using 1 larger somfy sonesse motor but in the end the complication of getting control over their proprietary RF control was too complicated and expensive for me to do right now. these smaller LT30's will do the job with a bit more noise but a lot more ease in terms of simple IR control. I just found out they are discontinuing these motors but with a 5 year warranty and light use ( compared to daily opening of shades which is what they are designed for... Im sure they should be good for a while.)
Here is my screenwall. Before pic
Here are the motor, tube and brackets, IR sensor, and remote for the right side
Here is the motor end with the locations for plugging in the iR sensor and the power supply
Here removing the stock plug end from the motor to replace it with the adapter for the skyline brackets I'll be using.
old vs new plug end for motor bracket adapter
Now ready for mounting to skyline bracket
skyline bracket installed on bottom with screws.
cut tubes to length on chopsaw
install skyline heavy duty plug end on side opposite motor.
plug in IR sensor and power supply after sliding motor/tube assembly onto brackets.
And thats it. Drop some batteries into the remote and done!! Works like a charm. Do the same for both sides and ready for the next step.
Here I have purchased VHMW plastic and used a hand plane and table saw to get it to fit in my track. Moggie used Delrin. but i'm gonna try this stuff instead. its was 3 dollars for the amount I needed so if it doesnt work no big deal. So Far it slides great but next come drilling and tapping it so we'll see how it goes.
this is as far as I have it now
Will update as I move along
Sony HW50ES | Denon X4000 | Rocket RS850s | Rocket RS200 | Rocket RS750s | Rocket RS250s | Quad Stereo integrity 18" d4 sealed subs | Inuke nu46000 | MiniDSP | Oppo 103D
My Build http://www.avsforum.com/t/1510721/the-bass-for-the-98-diy-build
MALIX is offline
post #2 of 7 Old 03-27-2014, 10:16 PM - Thread Starter
MALIX's Avatar
Liked: 33
Got a little more done.
I affixed the t track to screen wall frame with some blocks made fron 3/4 ply.
Then I attached the 2" wide aluminum bar (this will serve as the leading edge of the masking.) to the VHMW slides.
Make sure to make elongated holes in the aluminum bar ( as originally suggested by Moggie) to prevent binding as it slides along the track. Also make sure your upper and lower tracks are square and parallel to one another also to prevent binding.
I decided to do some testing so jerry- rigged some cord from the roller tube to the aluminum bar/ leading edge of masking. Then I ran some 1/8 inch bungee to provide tension for the masking to close. ( same as Moggie)
This was after trying 1/4 inch bungee and determining it was too much tension for the motors.
MALIX is offline
post #3 of 7 Old 03-27-2014, 10:45 PM - Thread Starter
MALIX's Avatar
Liked: 33
Heres a quick video that shows my test.. Not perfect yet but close enough to continue onto the next step
Gunnar and nandkisham like this.
MALIX is offline
post #4 of 7 Old 03-31-2014, 06:03 PM
armstrr's Avatar
Nice!
armstrr is offline
post #5 of 7 Old 04-06-2014, 01:22 AM
DjDonnyD's Avatar
Malix, AWESOME!!! Thanks Soooo Much!:)
DjDonnyD is offline
post #6 of 7 Old 10-11-2015, 10:55 PM
Quoted: 12 Post(s)
Liked: 0
very nice. Cant believe it only cost under 400. I will try to make one of this for my new HT since we are on the budget.
maciawa is offline
post #7 of 7 Old 10-17-2015, 03:32 PM
Quoted: 12 Post(s)
Liked: 0
BTW how long did it take you to do all this? and how would u rate the difficulty? thanks
maciawa is offline
Reply DIY Constant Height
