Is the Panasonic ae8000u the cheapest projector for CIH? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-13-2014, 08:48 PM - Thread Starter
Flavio Amorim's Avatar
Is there any more affordable projector?
Flavio Amorim is offline
post #2 of 4 Old 07-15-2014, 05:43 AM
stanger89's Avatar
Quoted: 2634 Post(s)
Liked: 1354
You might get more hits if you post this (or have the mods move it) to the regular CIH forum, I think it gets more traffic.
But the answer depends on what features you require. If you require lens memory then I think yes, it is the cheapest. Though if you keep an eye out for some B-stock JVC RS4910's they might come surprisingly close and be substantially better.
stanger89 is offline
post #3 of 4 Old 08-05-2014, 05:14 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
My 6 year old Sony VW60 still works fine for CIH, I get bulb every 2 years.
Where I'm going is IMO the PJ's going to 4k puts doubt into buying a new 1080p PJ today.
I'd instead spend "just" say $1k for a decent used PJ, then in 2017/2018 go 4k PJ....
mtbdudex is offline
post #4 of 4 Old 08-06-2014, 05:34 AM
stanger89's Avatar
Liked: 1354
That's a tricky question, personally, a $1k projector would not be good enough for me to 3-4 years. For that sort of lifespan I'd be looking at something like an RS49. But then again, aside from my current Planar 8150, I was dropping $2-3k on a projector every year or two.
Reply DIY Constant Height
