Cheap coating opportunity for USA prisms - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 219 Old 08-05-2007, 10:21 AM
phoveo's Avatar
Well - I just popped over to the DIY Screen forum, and, I will see you guys in a few months...
-- Keith
phoveo is offline
post #182 of 219 Old 08-05-2007, 03:40 PM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
There is a bit of reading over there
Mark
Mark Techer
I love my Constant Image Height system!
CAVX is online now
post #183 of 219 Old 08-06-2007, 12:49 PM
sknyfs's Avatar
Originally Posted by CAVX View Post
I also finally mounted the Perspex plate with sprung loaded bolts for easy tilt adjustment.
Mark
Mark, where did you find those. I might check HD on the way home today. I need to do something with my setup (got it from you) I finally mounted the PJ and Sled and Lens. I was about to screw the frame to get the proper tilt until I saw that statement. Thanks for saving your .. I meam my Lens frame from sure destruction.
-- Russell
Loganed - A long time ago.
My DVD Collection
My Build Thread - "under construction"
PSN: AtsymSknyfs
sknyfs is offline
post #184 of 219 Old 08-06-2007, 06:50 PM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
Russell,
I sourced the Perspex from the same plastics guy that made the original water prisms for me back in 2005. It is just a 360mm square plate that I attached to the base of the projector using the 4 M5 bolts on the bottom on the unit.
I lined the plate centre to the main MDF board, drilled holes right through and then used springs to space the perspex away from the MDF. The springs compress to allow precise adjustment. I didn't include the Perspex with the sled as there was too many variables with different makes and model projectors.
Take a look at the image to see how I did mine...
Mark
Mark Techer
CAVX is online now
post #185 of 219 Old 08-06-2007, 07:21 PM
sknyfs's Avatar
Russell,
Mark
I already have build something and used wing nuts similiar to what you have to mount my projector ( I have 4 - 5 inch screws sticking out for adjustment). I thought you where refering to the nuts/screw used for the lens tilt. It seems that whatever I do, no matter how tight I make the 2 outside screws the lens always seems to move.
My DVD Collection
PSN: AtsymSknyfs
sknyfs is offline
post #186 of 219 Old 08-06-2007, 09:20 PM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
There is a fair amount of weight there, but I not had any problems with lens tilt in the past...
Mark
Mark Techer
CAVX is online now
post #187 of 219 Old 08-07-2007, 07:56 AM
sknyfs's Avatar
Mark
What's the size of those 2 screws. I hate metric.
My DVD Collection
PSN: AtsymSknyfs
sknyfs is offline
post #188 of 219 Old 08-07-2007, 03:48 PM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
They're actually imperial - 3/16" x 1.5". I used imperial as I knew it would be easier to find than say an M5 bolt. If they're not tightening up, the tee nuts may have striped out from the MDF...
Mark
Mark Techer
CAVX is online now
post #189 of 219 Old 10-01-2007, 07:01 AM
Gerry S's Avatar
After seeing how small those french prisms are, I was wondering if you could get by with the Crystal Factory CWD46 lenses (4" x 6") as opposed to the 5"x7" ones everyone in this thread ordered.
If you could do it over would you use the smaller ones? Would the smaller ones still work? Thanks.
Gerry S is offline
post #190 of 219 Old 11-27-2007, 08:18 AM
adude's Avatar
Quoted: 50 Post(s)
I finally put together the case and the slide mount for these lenses. Put the prisms in the projector light path and tested with the anamorphic HCFR image. I am noticing very bad chroma aberration only on the right side. On the left side, its way way lower. Just to give the idea about prism placement, this is the view from the top. The projector and lens is ceiling mounted.
Also, one thing that I notice, each lens is expanding only on one side and have very little effect on the another. Is this how its supposed to mean?
adude is offline
post #191 of 219 Old 11-27-2007, 07:34 PM
Steve Scherrer's Avatar
That is my experience as well. Each prism expands half of the image.
The CA on the side can be remedied using masking.
Registered U.S. Patent and Trademark Attorney
Steve Scherrer is offline
post #192 of 219 Old 11-27-2007, 07:42 PM
adude's Avatar
Quoted: 50 Post(s)
Well, the right 25% side of the screen is badly affected by the CA. If I can somehow make the CA uniform, by reducing it on the right side and increase on the left.
Any ideas? some position change in the prisms?
adude is offline
post #193 of 219 Old 12-08-2007, 01:37 PM
adude's Avatar
Quoted: 50 Post(s)
Okay, I played around the distance between two prism and noticed that one prism was tilted little bit in other direction as well. I made it straight and CA on both sides became uniform.
Also, one thing to remember. The picture on the screen without the lens should be exact square. Any distortion in the shape will be magnified by the anamorphic lens.
Now back to enjoying movies.
A. Dude
adude is offline
post #194 of 219 Old 03-05-2008, 09:37 AM
bmwracer3's Avatar
Is L&L still doing this?
bmwracer3 is offline
post #195 of 219 Old 03-26-2008, 09:43 AM
bmwracer3's Avatar
I guess it would have been easier if I just called them. I just talked to a gentleman there and they will do the one-off's like me. $80 + shipping, and I can't argue with that. They will just work the lens in with another order so we don't have to pay the $500+ that it would be for a custom order. AWESOME.
post #196 of 219 Old 04-13-2008, 06:03 PM
Uther's Avatar
I'd still like to see some side-by-sides of the coated prism-based lenses compared to the professionally made lenses. Anyone tried this?
Uther is offline
post #197 of 219 Old 04-13-2008, 09:39 PM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
In my shoot out last year...
Mark
Mark Techer
CAVX is online now
post #198 of 219 Old 04-14-2008, 04:55 AM
bmwracer3's Avatar
I believe Mark/Cavx did that on his website...http://cavx.blogspot.com/2008/01/ana...shoot-out.html
edit: Sorry...I forgot to hit the post button last night.
post #199 of 219 Old 04-14-2008, 07:00 PM
Uther's Avatar
Kudos, Mark - very respectable given the $2500 (US) price difference between yours and the commercial lenses. Do you have any additional close-up of the outer 1/3 of the screen? I'm particularly interested in the focus in a real-world image in the outer edges of the frame as I think this would be the most distracting issue for me.
Uther is offline
post #200 of 219 Old 04-14-2008, 08:18 PM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
Thanks I will document the benefits soon as I develop the "CAVX Corrector". I have a prototype in development (a work in progress) now...
I will also have a 1080projector by the end pf the week too!!!
Mark
Mark Techer
CAVX is online now
post #201 of 219 Old 05-22-2008, 09:02 PM
adude's Avatar
Quoted: 50 Post(s)
CAVX,
Any update on your latest lens?
adude is offline
post #202 of 219 Old 05-22-2008, 11:40 PM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
CAVX,
Normally I would breaking rules, but seeing as how you asked, coated prisms will be available soon and I am also hoping for (in limited numbers) achromatic doublets for CA correction...
Mark
Mark Techer
CAVX is online now
post #203 of 219 Old 05-23-2008, 09:25 AM
Person99's Avatar
Liked: 125
This is pretty exciting. I thought you already investigated this and ruled it out!
Person99 is offline
post #204 of 219 Old 05-24-2008, 06:47 AM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
Never say never
Mark
Mark Techer
CAVX is online now
post #205 of 219 Old 05-25-2008, 08:13 PM
adude's Avatar
Quoted: 50 Post(s)
This looks promising. I am on the verge of re-doing the anamorphic lens. I am thinking of two ways:
Option 1 - Build a lens from the guts of Hi-Lux Variable anamorphic lens. It has prisms + some kind of correction glass in the front. This lens is meant for long throw, so prisms are too small for projector use. I noticed that the prisms have lot of gap at the beginning, between the prisms and the end. If I can build a smaller housing for these prisms, the image may just fit on these.
In my short test of the Hi-Lux, it looked lot sharper than the my current DIY lens.
Option 2 - Avoid all the hassle and go with the Aussimorphic III. I guess it will be better to wait.
adude is offline
post #206 of 219 Old 08-14-2011, 01:18 PM
f430's Avatar
I never used my prisms
I was cleaning the basement and found them new in box.
Anyone want them?
BenQ W1070 - DENON AVR-E400 7.1 - SLS Q-Line Gold - Hsu VTF-2 MK4
Watch the progress http://www.avsforum.com/t/1517374/budget-build
f430 is offline
post #207 of 219 Old 08-31-2011, 09:59 AM
kgveteran's Avatar
Quoted: 470 Post(s)
Liked: 174
Hey Mark, can i get your MKII lenses coated ? Or are they and thets the best it will get
kgveteran is offline
post #208 of 219 Old 09-01-2011, 03:44 AM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
Of course you can Proper multi broad band coatings will be way better than the "anti-reflective" coatings they gave me on the glass at production.
Mark Techer
CAVX is online now
post #209 of 219 Old 09-01-2011, 04:40 PM
kgveteran's Avatar
Quoted: 470 Post(s)
Liked: 174
Interesting. Where do i go from here.....
post #210 of 219 Old 09-01-2011, 07:14 PM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
From page 1 of this thread:
Originally Posted by rcgustafson View Post
Richard at L&L Optics in Mission Viejo, California, www.llopt.com, quoted me $50. per pair of 5x7 prisms if I can put together a group purchase of at least 12 pairs...
...The cost to coat one pair is $525. and I find this prohibitive.
Which is partly why good optics cost as much as it does.
Still worth giving them a call though.
Mark Techer
CAVX is online now
Reply DIY Constant Height
