DIY Prism - 4x6 too small? - AVS Forum | Home Theater Discussions And Reviews
Old 05-07-2007, 09:42 PM - Thread Starter
sillymeeee's Avatar
Hello!
I am planning to go DIY. I am getting an HD70.
I am confused about the size of the prism. I see many designs that have a 5x7 prism size....can you use a 4x6 or is that too small to project through? How to determine the size you would need? I would rather save some money on the smaller size prism if that will work.
sillymeeee is offline
Old 05-07-2007, 10:25 PM
Mupi's Avatar
Liked: 26
It depends on the size of the beam. 4''x6'' should be fine for
most PJ's. Just put a white paper in front of the lens and measure
the size of the rectangle.
where are you planning to get the prisms?
If you are getting those plaques from massillon plaque, dont waste your money.
http://www.massillonplaque.com/produ...4&productid=85
I just got the 5''x7''. it is almost like mirror finish and gives too much reflection.
Even if this prism is coated it may not be good as they probably have polished
it like a mirror purposefully.
Even if you get it from elsewhere in US like crystal factory it might be the same
as it might come from the same glass manufacturer. These online places are
just distributors.
I have not yet seen posts from any one who bought the prisms from crystal factory
and got them coated.
I have ordered a set of prisms from Sam. They are much smaller. have to
wait and see how they perform.
The image quality will not be bad but the main drawback of the DIY
lenses is the reflection from those uncoated prisms.
Those massillonplaque prisms also put reflections right on the image.
Didnt mean to be discouraging, just my experience.
Mupi is offline
Old 05-08-2007, 12:42 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Mupi,
Like mine, Sam's prisms are coated...
Mark
Mark Techer
I love my Constant Image Height system!
CAVX is offline
Old 05-08-2007, 05:11 PM
Mupi's Avatar
Liked: 26
Originally Posted by CAVX View Post
Mupi,
Mark
yep
Mupi is offline
Old 05-15-2007, 04:53 PM - Thread Starter
sillymeeee's Avatar
Hello again!
Since I will not be getting my HD70 until the end of June...Can someone who has one do the white paper test and let me know if I can get away with a 4x6 prism instead of a 5x7.
I am planning on having the projector around 13 feet back in a semi-light controlled room.
Old 05-30-2007, 04:01 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
How wide is the screen?
Mark
Mark Techer
CAVX is offline
Old 06-30-2007, 06:30 AM - Thread Starter
sillymeeee's Avatar
Hello!
I just picked up my HD70! I did a quick test on the wall last night with my VOOM box and a DVI to HDMI cable....awesome! Phase two will be screen design. My situation is a little different....the screen will be hidden during the day...and brought out when it is movie time. The wife does not want a big screen hanging around all the time. As soon as I figure out how far back the HD70 will be...I will start the 2.35 screen.
Old 06-30-2007, 12:13 PM
Steve Scherrer's Avatar
Originally Posted by sillymeeee View Post
Hello!
My wife is the exact same--whereas I consider the big movie screen to be something to show off, my wife wants it hidden away. So, we have a DIY roll-down screen (2.35:1 of course) hidden behind a valence that rolls down in front of a large window at movie time.
Registered U.S. Patent and Trademark Attorney
Steve Scherrer is offline
