Constant Width setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-12-2007, 02:04 PM - Thread Starter
Bruce Wayne's Avatar
I want to do constant width, if the prisms are 4.33" x 2.75" would I turn them sideways, which means I would only have the 2.75" to fit the width of my image into?
How to identify a future projector owner, he's the kid sitting two feet from the 42" plasma.
http://www.avsforum.com/avs-vb/showthread.php?t=954837
Bruce Wayne is offline
post #2 of 3 Old 12-12-2007, 04:14 PM
Fellenz's Avatar
Do you mean constant height, for constat width you shouldn't need any prisms just buy a projector and go.
RGB
CRT Forever
Fellenz is offline
post #3 of 3 Old 12-12-2007, 06:06 PM
Nasty N8's Avatar
He wants a vertical compression lens. And technically yes that is what you would do.
Nate
www.NastyPerformance.com
10,000 Watts, custom built speakers, 10' CIH screen = Holy Crap
Nasty N8 is offline
Reply DIY Constant Height
