158" DIY Curve Screen Completed - AVS Forum | Home Theater Discussions And Reviews
Old 01-04-2008, 05:15 PM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
Here are a few pics of my curve screen. Thanks to everybody who posted ideas before.............
Screen is 146" x 62" at 42.5ft radius
Cars movie......
Front of the theater
Here is the projector and HTB-AR anamorphic lens mounted inside the hushbox.
Additional Pics located at the link below.
nosdude is offline
Old 01-06-2008, 01:37 AM
dangc's Avatar
Wow, very nice!
How far from the screen is your front row?
What projector are you using?
What is the screen made out of?
dangc is offline
Old 01-06-2008, 05:16 AM
T_MINTON's Avatar
nice screen.my question tho, is that an air vent directly inside the hush box? I would tend to think that would introduce dust and in turn be sucked into the pj. NOT GOOD
T_MINTON is offline
Old 01-06-2008, 01:48 PM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
The air duct is blocked to prevent that..... Thanks for your comment.
nosdude is offline
Old 01-06-2008, 01:50 PM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
Originally Posted by dangc View Post
Wow, very nice!
The front row is 15ft from the screen and the second row is 20ft. I'm using the Optoma H77 HD2 projector (Old but it works and support 1920x1080.
I bought the 1.3 gain screen material at ebay for about $120.
nosdude is offline
Drewbert's Avatar
Whats that beast of a screen made of?
*NM posted above
Looks good!
Drew
Drewbert is offline
Old 01-06-2008, 01:54 PM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
*NM posted above
Looks good!
The screen is "Matte White, Rubberized canvas" bought at ebay.
nosdude is offline
Old 01-06-2008, 05:51 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
How did you make the curved frame?
oman321 is offline
Old 01-06-2008, 07:39 PM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
Look at this thread (Compliments of "tr6"):
http://www.avsforum.com/avs-vb/showt...=933667&page=2
I used the pictures at the beginning of the thread to construct my curve frame using 2x8 lumber.....
nosdude is offline
Old 01-07-2008, 02:39 AM
dangc's Avatar
Wow, you are using the H77 and you feel like you have enough light on the screen? This is very positive as I planning a 149" screen and my front row will be at about 12.5' and second row at 17.5'. I will be using a 1080p projector so I am hoping the viewing distance will be ok.
dangc is offline
Old 01-07-2008, 06:39 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Cool, I am familiar with tr6's thread. I am planning to do something similar if I don't go the way of a metal frame.
oman321 is offline
Old 04-16-2008, 03:45 PM
Person99's Avatar
Liked: 125
Then it is not 1.3 gain. In fact, it is likely not even 1.0 gain. Just FYI.
Person99 is offline
Old 04-16-2008, 08:27 PM
Heavywait's Avatar
Very cool great job, what is the design on your side wall made of?
Heavywait
Frankfort,Il
Heavywait is offline
Old 04-24-2008, 11:48 PM
syncguy's Avatar
Thanks for this. Looks very nice.
You have raised back row seats. What is the best (or the easiest) way to achieve this.
syncguy is offline
Old 04-29-2008, 07:59 AM
mandarax's Avatar
syncguy easiest way is to get seats that raise ... is to buy seats that raise.
check out fortress seating .. the feet raise up
mandarax is offline
Old 05-02-2008, 05:33 PM
Big Sexy's Avatar
Your Theater is awesome!!!! How exactly did you curve your screen? Step by Step please I want to do the same thing...
Big Sexy is offline
Old 05-04-2008, 10:48 AM
syncguy's Avatar
Thanks. It looks impressive...
syncguy is offline
Old 05-09-2008, 09:39 PM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
Check tr6 thread. He has pictures. Thanks
nosdude is offline
