my 2:35:1 setup... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-30-2008, 08:36 AM - Thread Starter
Demetri99's Avatar
hello everyone. i have a room that is 11' x 26' can i run a 2:35:1 set up?? if i can, what size screen can i go with?? one more thing i saw two examples of this, which one is best?? a. a frame holding speakers off to either side of the screen or b. speakers behind the screen?? if you are wondering my fronts consist of 2 BP7002's (towers) & 1 CLR2002 (center) all Definitive Technologies.
Do It Once, Do It Right & Never Do It Again.
Demetri99 is offline
post #2 of 12 Old 01-30-2008, 09:18 AM
Nasty N8's Avatar
I have exactly the same room dimensions+6" width but a entry at the front. Screen size best I got with my towers on the sides is 91" wide 2.37. If you went AT you could do a 10' screen if the speakers are behind it. Really depends what you want out of it. What are your seating distances?
Nate
www.NastyPerformance.com
10,000 Watts, custom built speakers, 10' CIH screen = Holy Crap
Nasty N8 is offline
post #3 of 12 Old 01-31-2008, 07:38 AM - Thread Starter
Demetri99's Avatar
the room is still in the drawing board stage...
post #4 of 12 Old 01-31-2008, 09:29 AM
Nasty N8's Avatar
Well my goal is 10" screen 13-14' and 19-20' seating distances. Any closer than that is too close in my opinion some like it closer. Someday with the right room.
Nate
Nasty N8 is offline
post #5 of 12 Old 02-06-2008, 12:27 PM
Steve Scherrer's Avatar
Nate
Why does this post remind me of this movie???
Registered U.S. Patent and Trademark Attorney
Steve Scherrer is offline
post #6 of 12 Old 02-11-2008, 08:32 AM
Nasty N8's Avatar
And why is that?
Nasty N8 is offline
post #7 of 12 Old 02-11-2008, 11:04 AM
And why is that?
Well, because you said your screen was 10 inches. (By typing 10" instead of 10').
Watch this:
http://www.youtube.com/watch?v=WXGbwIkvh38
post #8 of 12 Old 02-11-2008, 03:15 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
Too funny Steve
Mark
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #9 of 12 Old 02-13-2008, 01:17 PM
popechild's Avatar
Quoted: 13 Post(s)
I say you go with a 25' wide screen, and 10' seating distance.
popechild is offline
post #10 of 12 Old 02-17-2008, 11:26 AM
KBMAN's Avatar
Quoted: 344 Post(s)
Liked: 171
I think I'm going with a 104" diag. 2.35 screen for my 26 by 15 appox room. Seating is 15 feet back for the 1st row and about 19 feet for the back row. This will give me an 8' wide screen.
KBMAN is offline
post #11 of 12 Old 02-18-2008, 10:04 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
That is pretty far back. 8' wide is 3.375' high (8 / 2.37 = 3.375) and you don't want to be sitting any more that 4x the image height which is 13.5' for the back row.
I would look at increasing the screen size...
Mark
Mark Techer
CAVX is offline
post #12 of 12 Old 03-28-2008, 05:17 AM
Tarzan_91's Avatar
Here's a good screen size calculator. Just to put in some values and test.
http://www.prismasonic.com/english/srceen_size.shtml
Tarzan_91 is offline
Reply DIY Constant Height
