Official OPPO DV-983H w/ ABT VRS FAQ/Dump - Page 145 - AVS Forum | Home Theater Discussions And Reviews
post #4321 of 5594 Old 10-23-2008, 09:00 AM
spectra57's Avatar
Originally Posted by Neuromancer View Post
I would just try another cable to ensure it is not related to a bad pin, connection, or dropped bandwidth. Snow, sparkles, or other isolated visual errors are almost always associable to a bad cable.
All firmware revisions which are 08-0709 incorporate instructions which are compatible with all hardware revisions. It is only an issue with reverting to older firmware where the single chip solutions will have dropout and other errors at 1080p.
What exactly are sparkles?
spectra57 is offline
post #4322 of 5594 Old 10-23-2008, 09:40 AM - Thread Starter
Neuromancer's Avatar
Quoted: 83 Post(s)
Liked: 319
Sparkles = colored colored dots. You will usually see these around edges which are around high contrast areas.
Neuromancer is offline
post #4323 of 5594 Old 10-23-2008, 01:04 PM
spectra57's Avatar
post #4324 of 5594 Old 10-24-2008, 01:57 PM
Rottweiler29's Avatar
Damn this is a great player, Just watched the 20th Anniversary DVD of "Child's Play" on it and it looked amazing. Granted the DVD is of a high quality anyway, but still!
My only grumble is that sometimes when I try to close the tray the blue circle around the eject button on the player stays on and the tray won't close till I push it in with my finger.
Rottweiler29 is offline
post #4325 of 5594 Old 10-24-2008, 06:34 PM
GSB
GSB's Avatar
The eject button on the player requires a more deliberate push... pausing for a half-second as you press it, perhaps to avoid ejecting after an accidental press.
Gary
GSB is offline
post #4326 of 5594 Old 10-24-2008, 07:48 PM
Ah I see. I'll start doing that from now on and see if it eliminates the problem. It is strange. The "Close/open" text is displayed at the top left of my screen but the tray just won't budge until I push it with my finger.
post #4327 of 5594 Old 10-28-2008, 09:37 PM
Michel1973's Avatar
De-interlacing Mode 2:2 Even / 2:2 Odd / Auto
Video Mode Video 2
TV Type Auto / PAL (no differences)
720p
Latest PAL firmware
I watched more then 25 PAL discs.
Forcing one of the 2:2 Modes brings good movie quality but then the subtitles are combing.
Chanching to the other 2:2 Mode brings good subtitles but then the movie is combing.
Auto does not perform well either
Can anybody help me please?
Michel1973 is offline
post #4328 of 5594 Old 10-28-2008, 10:10 PM
Michel1973's Avatar
I can't stand the errors in the subtitles
In the past, I used Yamaha, Silvercrest and Pioneer and they didn't have these error!
All had Mediatek decoders.
I now this because I like to open up things
It's frustating that Oppo can not fix this.
But I trust them and keep on hoping.
post #4329 of 5594 Old 10-29-2008, 12:18 AM - Thread Starter
Quoted: 83 Post(s)
Liked: 319
Subtitles can suffer from sync to frame issues. As you have noted, you can improve the sync to frame with subtitles, but at the expense of video quality. In the current state, you will just need to which is more important: video or subtitles.
post #4330 of 5594 Old 10-29-2008, 02:11 AM
Vagabond's Avatar
I agree, the subtitle issue is getting quite annoying. I hope they can fix it, although I'm not sure they'll be able to.
However, this issue really must be fixed in their upcoming blu-ray player...
cheers
It's not magic. It's science.
Vagabond is offline
post #4331 of 5594 Old 10-29-2008, 03:37 PM
hodges69's Avatar
Quoted: 60 Post(s)
Liked: 44
Having a hearing loss,I use sub titles with every movie i pop in..
And to tell the truth,it really doesn't bother me all that much....I know that the price of this player dictates that subs should be perfect....but I will start to worry when pencils are made without erasers....
To me,it's a very small price to pay for the superb PQ I get with the OPPO playing thru my 60" elite..If I had a choice between a flawless sd Player,or my present OPPO...guess what my choice would be?? And what would you guys do??:
hodges69 is offline
post #4332 of 5594 Old 11-03-2008, 09:06 AM
Gary
Nope it's definitley faulty. It won't even close when you turn the power off now. Being replaced wednesday.
post #4333 of 5594 Old 11-03-2008, 03:26 PM
ricardochu's Avatar
started an instant problem with my 983, when i turn on the player the regular picture appear on the screen but after a moment the video signal goes out, i thought maybe it was an active screensaver so i press the eject button to load a disc but still no picture appear so i checked the hdmi connection and the connection looks fine then i turn it off and on again the picture appear and suddenly it happened again no picture, so i unplugged it and leaved it for an hour and i tried it again and it works fine now, used it for 3 hours and it never happened again, why is it i experieced these? i asking these because i'm afraid it might happened again.
ricardochu is offline
post #4334 of 5594 Old 11-03-2008, 04:33 PM - Thread Starter
Quoted: 83 Post(s)
Liked: 319
This is a classic HDCP handshaking error. Try replacing your HDMI cables and trying another software installation.
post #4335 of 5594 Old 11-03-2008, 07:02 PM
kitchen_space's Avatar
Any chance Oppo will consider a firmware change to eliminate the User Operation Prohibition (UOP) on DVDs (such as the fbi warning or coming attractions)?
kitchen_space is offline
post #4336 of 5594 Old 11-04-2008, 12:11 AM
GSB
GSB's Avatar
Don't know.
Do you know about the STOP then MENU button trick? Or hitting MENU as the "DVD-Video" message appears during loading? These techniques can bypass a few of those annoying UOP's.
Gary
GSB is offline
post #4337 of 5594 Old 11-04-2008, 04:23 AM
ricardochu's Avatar
thanks Neuromancer, may i know what does HDCP handshaking error means? does that mean my hdmi cable was defect? when i bought these player last september i watched several movies with these new hdmi cables without experiencing these problem except last sunday, and it has the latest firmware on it before the new beta firmware.
post #4338 of 5594 Old 11-04-2008, 04:38 AM
gonk's Avatar
HDCP (High-Definition Digital Copy Protection) is an anti-piracy protocol that requires an HDMI-equipped device like the 983H negotiate a "handshake" with a display that identifies itself via HDCP as being an approved display device.
gonk
Beta tester: BDP-83 / BDP-80
gonk is offline
post #4339 of 5594 Old 11-06-2008, 05:41 AM
Anthony A.'s Avatar
i have searched theis thread as best as i could, but i have not read all 145 pages. i am ready to buy this player, could someone list the current bugs/issues this player has as of today using the current firmware.
1) no seamless layer change (although many have reported pretty good)
2) subtitle combing (is this for pal only?)
3) hdmi handshaking (although i don't see this as an oppo problem)
thank you all very much for the help.
Anthony A. is offline
post #4340 of 5594 Old 11-06-2008, 05:47 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2799 Post(s)
Liked: 2029
I've seen it, but it is too quick for me to measure. Some small fraction of a second.
On NTSC discs I see subtitle breakup about once per hour.
Working pretty well, I think, although problem combinations are always a possibility.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #4341 of 5594 Old 11-06-2008, 05:47 AM
rdgrimes's Avatar
Quoted: 2087 Post(s)
Liked: 1416
I have experienced neither 1 or 3. Subtitles breaking up is very rare and brief when it occurs. Considering the complexity of the player and the multitude of features, it's very bug-free.
rdgrimes is online now
post #4342 of 5594 Old 11-06-2008, 06:34 AM
mariner still's Avatar
This is also my experience.
mariner still is offline
post #4343 of 5594 Old 11-06-2008, 07:25 AM
ggunnell's Avatar
. . . 3) hdmi handshaking (although i don't see this as an oppo problem)
The only "won't work with" I'm aware of is the Yamaha RX-Z11. I'd get confirmation on the Denon 4308, which won't work with the similar-to-983-VP-chipset DVDO Edge.
ggunnell is offline
post #4344 of 5594 Old 11-06-2008, 10:02 AM
hawkster27's Avatar
Quoted: 34 Post(s)
I am interested in controlling my new DV-983H with the remote that came with my Onkyo PR-SC885 preamp. I have been able to do this successfully with my Panasonic blu-ray player and my DirecTV receiver. Onkyo lists "1251" as the correct Oppo code. However, this does not work. Nor do any of the codes suggested on page 47 of the 983H's manual. Can you offer any further suggestions?
hawkster27 is offline
post #4345 of 5594 Old 11-06-2008, 10:18 AM
gonk's Avatar
Turn on "Alt RC Code" in the 983H setup and use some of the codes listed for Toshiba DVD players - it won't get you all of the controls, but it will get you all of the standard controls.
gonk
gonk is offline
post #4346 of 5594 Old 11-06-2008, 11:08 AM - Thread Starter
Quoted: 83 Post(s)
Liked: 319
You can also try codes from Marantz and Philips, though I have found the Toshiba controls to be the most usable.
post #4347 of 5594 Old 11-06-2008, 12:01 PM
BrandonB89's Avatar
Hello all first time poster.
I currently have the Sony BDP-S350 for watching up-converted DVDs and am wondering if the upconversion quality on the Oppo dv-983h is worth upgrading or am I better off just sticking with the S350. Btw I am viewing a 50 inch 1080p plasma tv from 10 feet away.
BrandonB89 is offline
post #4348 of 5594 Old 11-06-2008, 12:07 PM
wmcclain's Avatar
Liked: 2029
"Worth" is subjective. What kind of improvement are you looking for? In general, the difference between better quality players is more subtle than dramatic.
Are you using a calibration disc? I would put some time into that before buying new hardware.
-Bill
post #4349 of 5594 Old 11-06-2008, 12:21 PM
BrandonB89's Avatar
-Bill
I have used a calibration disc with great results. The reason I'm considering the dv-983h is that I want the best possible picture quality for DVDs and I'm just curious if the Oppo would give me that in relation to the S350 or is the difference so subtle it's barely detectable.
post #4350 of 5594 Old 11-06-2008, 12:28 PM
hawkster27's Avatar
Quoted: 34 Post(s)
Thanks for the quick response, guys. I should have noted that Alt RC Code is turned on. I tried the Toshiba codes (again) and still no joy. One more remote on the coffee table isn't that big a deal, but still...
Reply DVD Players (Standard Def)
