Panasonic DVD Firmware Update 200405 ISO - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-15-2008, 01:30 PM - Thread Starter
shadis's Avatar
I am trying to upgrade my dvd rv-27, so I managed to download this iso. I tried to burn it, both on dvd and cd, but when I put the disk in my dvd it says that it is an unsupported disk and won't play it. Can someone please tell me what I'm doing wrong?
shadis is offline
post #2 of 5 Old 09-15-2008, 02:04 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2690 Post(s)
Liked: 1921
Make sure you are burning it as a disc image, not as a data file.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #3 of 5 Old 09-18-2008, 04:26 PM - Thread Starter
shadis's Avatar
I found instructions that said to do both, so do both I did. I burned the image (cd and dvd), pulled the files and folders off the .iso and burned them (cd and dvd), nothing seemed to work. My dvd would spin for about 3 minutes and then say unsupported disc or somesuch.
shadis is offline
post #4 of 5 Old 09-18-2008, 05:10 PM
wmcclain's Avatar
Liked: 1921
Are you using Windows? I've seen this utility recommended for burning ISO files: http://www.imgburn.com/
Have you used this media with this player? Could be they are not compatible. You might try a different brand.
-Bill
wmcclain is offline
post #5 of 5 Old 10-16-2008, 08:52 PM
vellecadp's Avatar
Where did you find the file - I am in need of it as well. A link would be appreciated.
D
vellecadp is offline
Reply DVD Players (Standard Def)
