playing movies from USB stick - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-06-2008, 12:14 PM - Thread Starter
blackrain's Avatar
Quoted: 20 Post(s)
It seems that many people are using their USB hard drives with the latest USB 2.0 enabled divx/dvd players. I haven't seen too much talk about USB sticks. I am thinking about getting an 8 or 16 GB stick. Do movies play just as well and fluidly from USB sticks. I vaguely remembering trying to play a movie from a USB stick on a pc, and the USB stick would stop responding after a short time. Is there a specific type of USB stick I should get, or do they all work just the same? Can anyone confirm successfully using a USB stick to play movies?
blackrain is offline
post #2 of 3 Old 10-06-2008, 05:09 PM
Ultimateherts's Avatar
It would work the same except that the size comparison is a lot smaller for the sticks!
Ultimateherts is offline
post #3 of 3 Old 10-13-2008, 08:38 PM
triggle's Avatar
You'll want the fastest thumb drive you can get. I had a DVD drive (Phillips) equipped with USB but found it took longer to write a 4gig thumb drive than a DVD-R so I gave up on the idea. I did not try with an external HDD drive but I think it would work.
I do think that if the USB could be used to mount a huge external drive then it would be good. I believe the write speed of thumb drives is much slower then the read speed.
triggle is offline
Reply DVD Players (Standard Def)
